Ben's messing aroung with FreeEMS-Tuner code
- sry_not4sale
Re: Ben's messing aroung with FreeEMS-Tuner code
Merged master back into benfenner branch
It's better, but still a bit borked :-)
Ben :
http://freeems.aaronb.info/tracker/view.php?id=76
Enjoy :-)
									Ben :
Enjoy :-)
I'm curious if there has been progress on this "how to" I'm still McIgnorant when it comes to git. Your's was a windows GIT install yes? I'm looking just for the pull feature right now.BenFenner wrote:After spending 9,000+ hours with Aaron last night we finally got git working with SSH and I can now push my changes for Aaron to use in the master repository.
I plan on writing up a short "how to" on the process soon.
I've got git, git-gui, and a pile of others git's. Seems my problem right now is about this error message.
"fatal: Not a git repository"
So I'm still learning about that. Digesting the man file, for at least a couple more minutes.
git isn't easy like svn, but it has some certain features which mean svn will have to take a back seat. I'll be trying to keep two repositories from one master directory :-) hopefully it works out well for me.
I've been slacking on that. I'll get to it as needed I guess. =(jharvey wrote:I'm curious if there has been progress on this "how to".
Yes.jharvey wrote:Your's was a windows GIT install yes?
Pull was very easy for me to get. Or was it clone? Yah, it was "clone". Pull I think requires the whole SSH thing, but "clone" will download the entire repo, which is what you want I think.jharvey wrote:I'm looking just for the pull feature right now.
I think Aaron's the guy to talk to about all this. It went so smoothly for me I don't remember how to do it, and Aaron's the reason we're using Git, so he should have to field this sort of thing. =]jharvey wrote:Seems my problem right now is about this error message.
I can really only help with the SSH key part of the Windows Git experience, as I had quite a bit of trouble with that, so I know it better.
After you clone you can pull. You don't need ssh to do that. You only need ssh to push which I doubt Jared would want to do. I may get something setup so I can add my little hacks in though :-)
to clone you do something like :
and then after that you just do :
assuming you change nothing. If you change something you do :
to blow away your mess ;-)
EDIT to add dirname that I forgot, thanks Aaron ;-)
git clone <clone url> <directory to create>Code: Select all
git pullCode: Select all
git reset --hard HEADFred.
Reason: add dirname
									Reason: add dirname
- sry_not4sale
That error is because you are not in a git controlled directory when you are running a command.jharvey wrote:I'm curious if there has been progress on this "how to" I'm still McIgnorant when it comes to git. Your's was a windows GIT install yes? I'm looking just for the pull feature right now.BenFenner wrote:After spending 9,000+ hours with Aaron last night we finally got git working with SSH and I can now push my changes for Aaron to use in the master repository.
To create a git controlled directory, you need to either create a fresh repo or clone the FreeEMS one:
git clone git://github.com/srynot4sale/freeems-tuner.git dirrnameOwner / Builder: 1983 Mazda Cosmo 12at (1200cc 2-rotor turbo) coupe [SPASTK]
Not sure if I already linked you this or not, but here is a task :
That should be easy, as should...
And here is a new one that we discussed earlier :
http://freeems.aaronb.info/tracker/view.php?id=79
If anything is unclear, please comment and assign back to me or just ask on IM etc. I've included the packet details in there for Aaron to parse, assign it over to him when the gui aspect of it is done :-)
Didn't get Fred's PM in time so I've got the real-time data display finished first.
It doesn't work as there is no bad-end. Aaron will either put that in, or let me know when it can be completed (waiting on packet parsing I think).
I'll push the changes when I get home.
Thanks for that, and also, thanks for this :
Good work :-)
Good work :-)
