Dan's PNP RB25DET R33 Skyline ECU PCB
Re: Dan's PNP RB25DET R33 Skyline ECU PCB
Sensor is likely std Denso. If you can find the pull up value, I can do a curve and find the temps that correspond with your voltages, very easily. May already have it in stock.
Corbon
Post by Corbon »
I think that's the bugger. Meant to be used on most other Nissan's of the era also.
Standard Bosch NTC Sensor ( NTC M12 ).pdf
(124.61 KiB) Downloaded 726 times
Dan
Post by Dan »
Cool! Thanks Corbon! :-)
Bosch? On a Nissan? Really?
Someone's Nissan workshop manual:
viewtopic.php?f=24&t=100
Photos of the sensors on most Nissans match my Mazda one in the above thread.
My values match that workshop screeny, too.
The above Bosch has a similar curve, though.
Dan
Post by Dan »
I am very very close to having this PCB ready to be sent for manufacture!
I am aiming to complete the remainder of the work required today and let Fred, and whomever else is interested, have a day or so to review it before the order is placed.
I need this relatively quickly, so unless there are physical connections that are incorrect, shit with reverse polarity, etc I won't be caring about any comments relating to aesthetics initially.
I will post up when I have pushed the updated PDF and associated Altium files to git.
Stay tuned!
Sounds good. Let's go over it in real time via skype as soon as you're ready. Let me know when.
Dan
Post by Dan »
OK sounds great! :-) Will keep you informed!
masterkorp
Post by masterkorp »
I would volunter myself as one alpha tester.
I don't have knowledge to actually review hardware efficiently ( I plan to acquire it as times go by, always help bringing females onto my orbital field.), as long as you have a bill of materials and a pcb design you feel confortable with, I can build a board for myself, and start testing and aquiring data on a harsh environment. I plan to do it on a jaguar first, and keep both ecus runnable.
Dan wrote:I am very very close to having this PCB ready to be sent for manufacture!
A week later, no sign of it! Not that I mind, mind you, just pointing out that every time you do that it hurts your credibility to deliver. If you want my review, you have 3 days, max, to get it to me, probably less.
Excuse double posting the above :-)
