Peugeot 2.0 Turbo on CardS12
Matthijs
Re: Peugeot 2.0 Turbo on CardS12
Post by Matthijs »
12v square wave
3000rpm = 100Hz
idle = 30Hz (+-1000rpm)
So I can take that one out again an add a 2n2222.
Matthijs
Post by Matthijs »
I found out it has a SL494 on the tacho (Most frenchies of this era use these). Takes 5v at the input :)
Matthijs
Post by Matthijs »
Tried to fire up the car tonight but the timing light hardly comes on, if it does at all.
Can´t figure out just yet what is going on..
I´ve build my own FreeEMS-0.2.0-SNAPSHOT-230-g4e32dbf-DEV-MATTHIJS309T-MissingTeeth-Crank-60minus2.s19
Perhaps someone can take a look at the log file and enlighten me ;)
2013.11.02-23.15.48.rar
(253.25 KiB) Downloaded 1132 times
You shouldn't be trying to fire up the car until after you have checked the timing and have known good ignition.
Re log, "timing light doesn't come on" + "please look" = not enough, see this:
viewtopic.php?f=54&t=2323
You met 4 out of 7. Missed points are:
Log file must be accompanied by a description of state of the code, car, tune, weather, etc. You MUST tell me what you are expecting me to look for/at.
Log file must be accompanied by a self-analysis, why should I try to figure out what is going on if you will not. If you can't find anything, tell me what you tried and what you checked.
And might have missed this one, or not:
Log file must be generated by a firmware version that has no uncommitted changes, and that is pushed to a public Github account, or a private one that I have access to.
But I won't find out till the others are sorted.
I know the state of your car/hw more or less, but what about your ignition hardware? How about your config and tune and your attempt to diagnose it? Post again with these :-)
Matthijs
Post by Matthijs »
Hi Fred,
By firing up I meant to say: In the progress of firing it up. I only did timing check (as you mentioned earlier on IRC) and it didn't work out.
It was 1 am here, the GIT merge didn't work, I posted the log on here just for a global review, perhaps a sensor was way of or missing.
For the other missing points:
Code: I'm running the vanilla brench, no mods except for the fixed tuning files, no -dev.
Tune: flat -10 degrees ignition, flat VE 60 tables, 60minus2 crank.
Weather: rainy, windy, +- 10 degrees C, dark outside :P
Etc: Just had my hair cut :)
The car is able to run on the stock ECU (which I tried also between the FreeEMS attempts)
The timing light went on for about 2 or 3 times at a random point so the ignition outputs of the EMS seem to work. Prime works.
At the IRC:
[00:22] <@malcom2073> It's getting a sync resetting every 58 teeth heh
[00:23] <@malcom2073> And every time you stop cranking, it starts working for a moment while the enigne slows down, really odd
[00:25] <@malcom2073> What resistor do you have between the two legs of the VR, + and -?
[00:25] <@malcom2073> just before the input to the MAX chip
[00:25] <Matthijs309> 5,6K 3 watt
[00:26] <@malcom2073> My car was doing something similar, fred had me move down to a 1k, and it works a lot better now
[00:27] <@malcom2073> improves the noise immunity a bit
[00:27] <@malcom2073> Worth trying
I might do that. Could it be causes by the VR + and VR - being swapped around?
I'm going to try to merge the GIT files (complains about the simeon config you added to my fork and now I can't push anymore)
2013.11.02-23.15.48.zip
Log file now as zip instead or rar
(331.01 KiB) Downloaded 1152 times
Matthijs
Post by Matthijs »
I think I've uploaded/merged all to my fork:
https://github.com/Matthijs309/freeems-vanilla
