1,2,3,4 awesome work! :-)
Looking forward to IAT install plus hacking in some accel enrich for you.
Will look at log now.
									Andy's 1996 GM 3.1L V6 in a 1932 Ford Coupe (11th)
Re: Andy's 1996 GM 3.1L V6 in a 1932 Ford Coupe (11th)
Andy, your EGO input is FULL of extreme noise. Is the grounding on your LC-1 install correct? They're noisy devices :-)
I will double check the grounding of the LC-1 and make sure the analog output signal wire is no where near the sparkplug wires.
