PCB layout - DaveBMW
davebmw
Re: PCB layout - DaveBMW
Post by davebmw »
Have been working on the Analog and digital input protection and conditioning sch today,
next on the list is VR conditioner
Bump, see my post in Jared's thread :-)
davebmw
Post by davebmw »
Fred, Eh????
Update:
I have been working on a side project for work and for home use, its basically a PIC18F4550 used as a USB DAQ for connection to a PC to provide 8 digital inputs, 8 digital outputs, 8-10 Analogue inputs, 4 Analogue outputs, 4 PWM outputs or capture and compare inputs.
The initial idea is for use with LabView which I am learning at the moment. However this little project has the potential to become considerably more than a simple I/O device, maybe a piggy back datalogger to extract through experience the OEM setup to program into the freeEMS.
or
Knock signal processing or Ion sensing with comms back to XDP via SPI or CAN.
the possibilities are quite fruitful.
On the FreeEMS Tybe B front I have the digital protection and analogue conditioning sorted, the VR circuit I have a couple of options the first and easiest is to use the LM chip, I have been looking to perform the same task with a simple OpAmp circuit not quite sure which one i'll choose yet.
Next task is to capture the knock signal and find a way for the PIC to pull that signal from the noise and act upon it. For this i will need a decent day with minimal rainage to get out on road and record the signal as an audio file.
looks like a busy weekend again.
Keep up the good work :-)
davebmw
Post by davebmw »
You too! Steak and Cheese pie eating compadré.
Pilt
Post by Pilt »
How about fiting two TPIC8101 or HIP9011 knock sensor ICs on the board?
davebmw
Post by davebmw »
Pilt wrote:How about fiting two TPIC8101 or HIP9011 knock sensor ICs on the board?
it may well end up having one, it would require a link to the XDP, I think on the SPPI that will need writing into the code, thats quite a bit out of my programming abilities at the moment.
But for now, as a safety net, a more discrete approx may be the way. Just something to provide a pulse out to the XDP and the software reels back the timing and could provide an advanced based auto-tuning facility.
davebmw wrote:it may well end up having one, it would require a link to the XDP, I think on the SPPI that will need writing into the code, thats quite a bit out of my programming abilities at the moment.
The trouble isn't that I'm not willing to do it, it's that there are 50 other things that need doing first that will take a lot of time.
In the last week I've realised that I have a mountain more work than I thought I did due to having to describe the data interface for the tuner guys (without which our ecu is useless). I'm on the case, but I need to finish your stuff first as those guys have lots more to do without the data spec already and you guys are waiting.
gearhead
Post by gearhead »
Dave,
Can you post your current version of this project? I would prefer if you put it on github so that we can all find it.
http://github.com/fredcooke/freeems-vanilla/tree/master
Create a directory, please and upload it. Any work you have done, I want to leverage as opposed to re-creating.
Gearhead
Gearhead, it's not a matter of creating a directory in freeems-vanilla and uploading it. It's a matter of creating a project for this and commiting and pushing the data. Each part of the project should have it's own source repository. This and Jared's sub-projects should be split out just like freeems-tuner is.
Having said that, I fully agree that we should get these pieces of work up in such a fashion and keep them versioned over time.
