Future Tuning Software User Feature Wish List (UI stuff)
Free Open Source Software project discussion forum. Post your Free Open Source software projects here!
Re: Future Tuning Software User Feature Wish List (UI stuff)
A commercial system running on my linux eee pc under wine. EMS stinger stuff if you want to try it.
sry_not4sale
Post by sry_not4sale »
Wheres the Big Red Button?
:mrgreen:
deviousKA
Post by deviousKA »
Heres an simple example of a 20x20 pseudo-3d table, written in C# with gdi+. source attached.
GabesGDI+example.zip
(36.79 KiB) Downloaded 986 times
devious, what is your name?
I couldn't find a binary in that zip. Am I blind? If you could provide a built one and let us know which version of the libs it is built for that would be awesome. I don't have mono etc setup on this box.
deviousKA
Post by deviousKA »
Hey Fred, name is Gabe. Might re-register here as Gabe_Z or put it in my sig.
Heres a compiled release of that example, let me know if it doesnt work/needs some extra dlls or something, first time ive compiled for use on another computer.
Ive been looking into mono myself, havent set it up on this pc (windows) and targeted it/used the framework yet, but from the reading I have done it should work fine. It uses .net 2.0, but the code may even be compatible with 1.x, im not sure how gdi etc. was implemented in those versions.
Release.zip
(7.24 KiB) Downloaded 1013 times
Thanks :-) Don't worry about the name change, pseudonyms are fine :-) I just wanted to know so I could refer to you in a more personal way.
/home/user> mono ./GabesGDI+example.exe
** (./GabesGDI+example.exe:24511): WARNING **: Missing method System.Windows.Forms.Control::set_DoubleBuffered(bool) in assembly /usr/lib/mono/gac/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll, referenced in assembly /home/user/GabesGDI+example.exe
Unhandled Exception: System.MissingMethodException: Method not found: 'System.Windows.Forms.Control.set_DoubleBuffered'.
  at <0x00000> <unknown method>
  at GabesGDI_example.Form1..ctor () [0x00000]
  at (wrapper remoting-invoke-with-check) GabesGDI_example.Form1:.ctor ()
  at GabesGDI_example.Program.Main () [0x00000]
I'm not certain I've done all I can to make it work though. I did install a winforms 2.0 lib but have to go and do things now...
shameem
Post by shameem »
Here's a screenshot if anyone's interested -
I havent gone through the code in detail yet - but it looks a like a good starting point
Thanks Shameem :-)
deviousKA
Post by deviousKA »
hmm, well, looks like mono doesnt support winforms doublebuffering. I should be able to figure out a workaround using a different sort of paintevent scheme.
You can remove those lines of code that are giving you an error with mono and it should compile and run, but the drawing is going to flicker when moving the cursor or any other update.
Could it be a missing library or did you google it up and find its not implemented?
