OK, CPU/clock time!
Four sections in this post:
- PLL
- Crystal
- Decouple
- Config
PLL
Use these values:
R175 = 3.3k
C93 = 6.8nF
C94 = 680pF
These should all be tight tolerance parts (1% and X7R) to ensure stability at frequency extremes.
Crystal
C96 is totally absent from your spreadsheet :-) Add it, and... :
R176 should not be necessary, but it does not hurt to order it, perhaps include 1M and 10M in the order, just in case.
C96/C97 are probably fine at 22pF, however this needs to be tuned in-circuit. I'd recommend ordering some smaller values and larger values too, just two of each, say 15pF and 33pF as well as the 22pF units. These should all be tight tolerance parts (1% and X7R) to ensure stability at frequency extremes.
Decouple
Freescale
require the use of ceramic X7R capacitors of 220nF/0.22uF for some of these parts and >= 100nF/0.1uF for others, so, make them all 220nF/0.2uF for consistency sake. Making them all 100nF/0.1uF is wrong and mixing them just complicates the order unnecessarily and provides reduced performance.
C95,C98,C99,C100,C101,C102 = 220nF/0.22uF
However!!! :
Do NOT forget that half of these are connected incorrectly.
Config
R177, R178, R179, R181, R180 = 10k, so yes, change to R180 is fine/good.
Connections look correct.
After this, I want to give it a full check and make sure that nothing is out of place and then it's order time! :-)
