PCB layout for Cinch ModICE enclosure
MotoFab
Re: PCB layout for Cinch ModICE enclosure
Post by MotoFab »
Great work fellas!
How did the git thing work out? Is this up on github or something?
KW1252
Post by KW1252 »
Working on it. I don't understand one bit how it works but perhaps a lucky break is lurking around a corner, who knows?
Have you seen the git thread in the freeems general section? worth a read. you can always ask me for help, you have my details. how are calls to other parts of europe for you? you can phone me in spain soon for some more personal assistance, if you like.
It it helps, If you get me the files, I can simply post them if you like. Or I can also help you walk through TotriseGIT.
Here we go, thanks for the help KW1252 Your models are much nicer and your modules layouts are also great.
https://github.com/jharvey/Cinch_enclosure_template
KW1252
Post by KW1252 »
Great job! :)
I've said it before, and I'll say it again, but .bak and .*~ files should be in .gitignore and not checked in. Otherwise, yes, I've got a copy, and it looks pretty compact :-)
I got to see the Cinch in person several days ago. I figured I'd post some notes. The heat sink bars are potted, and it appears they can't be removed. The case plastic is quite a bit more rigid than I expected. Also it looks like the above KICAD has the spring retainers backwards. I updated and pushed to github. Here are some pictures of how the spring bars should be installed, or at least that's now I believe they should be installed.
https://github.com/jharvey/Cinch_enclos ... clips1.png
https://github.com/jharvey/Cinch_enclos ... clips2.png
[edit]fixed above links, changed because I moved files in github[/edit]
jurpo
Post by jurpo »
FYI if anyone wish to use PADS for PCB design, I have made PCB templates suitable for ModIce enclosures.
...although I really don't believe that anybody wants to use PADS just because of its "competitive" pricing; schematic licence is "only" ~500USD while basic layout/PCB licences cost roughly 5000USD per piece. If anyone is using PADS for his/her hobbies it is probably just because that is available through work. :-)
