AiToR51's 1992 Ford Sierra XR4i 2.0 (24th)
AiToR51
Re: AiToR51's 1992 Ford Sierra XR4i 2.0 (24th)
Post by AiToR51 »
last log here (max 3 files per post)
log4.7z
(3.08 MiB) Downloaded 1965 times
Sierra XR4i 2.0T
Which log has the weirdness described? There are four now.
AiToR51
Post by AiToR51 »
log 1 for example had that near the giving record
Sierra XR4i 2.0T
OK, first things first: The "log 1" file has TWO logs in it. :-p
I opened both to the point you said and found nothing weird. You're used to MS1 logs... FreeEMS are MUCH faster and tell the truth somewhat more. Future RPM will be a bit smoother, but your logs look OK.
pishta
Post by pishta »
Are you running EDIS on this motor? If so, how did you integrate into FreeEms> I believe its just a distributor signal....?
Nope, he's not.
AiToR51
Post by AiToR51 »
No because I want ignition cut :P
Sierra XR4i 2.0T
AiToR51
Post by AiToR51 »
After a sabbatical year with a NA V6 and then with stock engine it will have a 2.0 turbo again. This time I'd like to install (and use,not like last time) a FreeEMS instead of my MS1.In first instance I would like to use the ruzki board so I can keep my current megasquirt board. I've also a Jaguar 0.7 I could use if I have problems with the first option.
About the engine, stock one is a ford 2.0 8v DOHC with 123bhp. It weakest point are the conrods, after breaking 3 engines by conrod failure I think it's limits are around 300Nm, over this it can break easly. In my last engine it broke when flatshifted from 2th to 3rd gear, it made a boost spike when lowering rpms and it explode. Probably if I didn't play with this kind of things it could have had last more time.
the best dyno graph I have from it is this@1bar with an old garrett T3 (Trim 55)
I had boost limited bellow 4000 rpm to 0.6bar to avoid extra torque, but after that launch I increased a little to around 0,8bar
The new engine will use the same engine block, but with forged rods and forged pistons. I'm waiting for the pistons.
About cylinder head I will use a 16v head, which have around 30% more valve area than the 8v.
Now I'm designing turbo manifold. I thought about making it with T3 twin scroll flange. My current turbo is single scroll but It's possible in future I will put a newer twinscroll one.
I'm taking measures on another sierra to don't stop mine
laser cut flange
some tests of fitting:
Pipes will be around 38mm inside diameter, a little less than cylinder head out to gain gas speed and gain spool. what do you think about this?
the unique problem I see is that modern garretts have the turbo outlet where my brake pump is.. that's a problem if I want to put a new turbo. But shouldn't be difficult to modify turbo flange angle If i weld it having this in mind.
Sierra XR4i 2.0T
AiToR51 wrote:Pipes will be around 38mm inside diameter, a little less than cylinder head out to gain gas speed and gain spool. what do you think about this?
How much smaller? If it's only a little, and you taper into it at the head, then it'll stay laminar-ish and you'll get OK flow out of them. I'd still prefer matched, though, as A) laminar matters and B) the collector and turbine housing are where you get your velocity increase IMO.
When I did mine, I had to choose between 44.5mm OD and 41.3mm OD with the IDs being 41.3mm and 38.1mm respectively. 38.1 was smaller than my ports too, and 41.3 was a pretty close match, so I went with that and I've been super happy with that.
Here's how it looked prior to final fitting:
I welded both sides, and then hit them all with the die grinder until they were pretty much bang on.
AiToR51
Post by AiToR51 »
I've to made some mods to made compatible ms1 v3.0 stock board with ruzkiboard as the ruzkiboard was made for ms2 with sequential injection mod:
- use std injector pins 21-22 instead of 39-40,
- change megasquirt injector FET driver (inverted) for a non inverted one
- adapt configuration for the ports ruzkiboard use
https://www.youtube.com/watch?v=OfxLsZHmg7U
I've pending a idle PWM control for continue making tuning
Sierra XR4i 2.0T
