Daniel's Volvo B5234T 5Cyl 2.3 Turbo (22nd)
Re: Daniel's Volvo B5234T 5Cyl 2.3 Turbo (22nd)
0 280 150 785
Sim,
Did use an excelsheet to get the deadtime, see atachment.
Got it from the MS site, didn't make it up myself.
Most injecjor producers use N-Heptane instead of gasoline to measure flow.
Don't have the weight figures on these.
- Dead time calculator.xlsx
- (14.38 KiB) Downloaded 1144 times
He's not done the tests yet, and is currently asleep AFAIK. I look forward to him uploading his raw data and we'll compare my calcs with the spreadsheet. Looks like a nice piece of work, but quite complicated. Gives me ideas for bespoke software tools, though, so thanks :-)
Would any one in NZ like to see this running for the last time on the engine stand?
the car that owns the radiator would like its radiator back so I'm going to run it for one last time on the stand so I can get the oil hot and drain it from the sump so that when I pull the sump off to hack the shit out of it so it will fit into its new home, the oil is mostly gone.
and for entertainment.
I would! When is the big event? Will be out and about today, so could make it west if it's convenient.
anytime this week in the afternoon should suit. the engine is back in the supra so I'll be working 24/7ish to get it running.
after 5 is best, to avoid annoying any of my neighbours that I actually like.
Will see if I'm over that way one of these evenings! If you need to get it done, take video, it's been enough until now, should be OK still ;-)
sure, do you have an NZ cell number yet?
Will be over on the shore soon, depending on how long we stay that way, may get out to your place in the evening. We'll see. Not yet.
