Prepare two fire extinguishers in case of emergence
Need to modify my injectors harness to do semi-sequential injection
here is how I do this
I found a nice place to do this job
clamp the endpoint
build my own adapter to switch from batch to semi-sequential
Test the adapter
2#/3# cylinder injectors' ground go to FreeEMS hardware directly
Build two ground for onboard igniters and all lowsides
Extend my vacuum line with a oil filter
Wire up the ECU, it sits right under my stock harness socket, save me a lot of wiring effort
Connect com port and here we go
The leds onboard is very useful
Because of cold start situation, I crank the engine, but no respond. I crank again, the engine fired but die immediately. I wait for 2 minus and fire it again, this time the engine start to roll and idle at 1300 RPM. A few minus, it rised to 1700 RPM. I shut it down and recrank it, this time the engine start rather happly. I think I need to tune the cold start enrichment
Here's the Engine parameters
I'll upload my video latter, poor quality, I should find another day to reproduce the video
