Hentai's 1992 Mazda Miata (15th)
Hentai
Re: Hentai's 1992 Mazda Miata (15th)
Post by Hentai »
Need to do the mod on the jag to make sure the timing is staying correct. It skipped my mind but I just remembered I still have the j&s attached. I plan to bypass it tomorrow and see if it is that effecting reving up since I see no data on the logs showing breakup from the CAS. IIRC when I used it on the ms2extra setup I had to tune down the dwell from 5ms to 3ms or else it would pull timing out and hit a wall. I suspect its doing the same thing again.
Piece of shit.
Hentai
Post by Hentai »
This was indeed the issue, I took the dwell down to 3ms and I was able to rev up properly and hit off the rev limiter.
Hentai
Post by Hentai »
Another issue is upon restarting hot, say 5 - 10 minutes after turning the car off the car runs lean for a while.
From IRC:
Re IAT sensor:
(20:27:54) Fred: where is it?
(20:28:45) Hentai: at the back of the engine bay
(20:28:50) Fred: LOL
(20:28:54) Fred: and you expect what?
(20:28:55) Fred: magic?
<SNIP>
(20:26:20) Fred: fix your car
Resolved :-)
Hentai
Post by Hentai »
I got the sensor installed just need to get a connector for it and good to go.
Hentai
Post by Hentai »
I think the hot lean restart was caused a lot by those old rx7 injectors, I have not noticed the issue as nearly as bad with my id1000's.
Also can't wait to get my jag a7
gonna be fully populated in inputs
Hentai
Post by Hentai »
Hentai
Post by Hentai »
injectors ID1000's still batch fire
http://injectordynamics.com/injectors/id1000/
43.5psi base pressure
1015cc
wastedspark
12-1 crank speed
1 cam sync
GM 3 bar map sensor
denso coolant sensor
gm iat sensor, open element
Commanded lambda load = tps
Hentai, this is done except for:
  • IAT and CHT, I need to know the bias resistor values on your Jaguar.
  • Scheduling pin out, I need to know if you've jumpered any FETs or not. If so, which to which CPU pins, if not, I can tell you what to do to match what I already did (same setup as previous Jaguar)
And not doing these right now:
  • Load type for Lambda, default for now. Will split out and let you do crazy stuff soon.
  • Cam sync/sequential, this has to wait for some refactoring and new functionality, no big deal.
  • Proper characterisation of the low pulse width regions, this needs new features, later. Should be good enough for government work as is.
What I did:
  • Researched new data for GM 3 bar and ID1000 (full curve generated!) and added to base firmware
  • Changed decoder from 4/2 to 12-1
  • Changed injector flow from 540 to 1015 cc/min
  • Changed scheduling to be correct for crank sync decoder
  • Configured 3 bar MAP for your car
  • Added a stanza to IAT for your GM sensor
  • Configured ID1000 dead time curve for your car
Let me know when you suss out those two final points, and I'll update and provide a binary.
