The Ravage opto schematic doesnt have resistors on the emitter outputs? only 10K pull ups on the collectors and 2K4 pull ups on the tx and rx lines from the micro that go to the anode of the internal diodes. The emitter and cathode pins should directly connect to ground. I know the datasheet used this as their "timing test" circuit or some crap, but that is irrelevant to us. All opto circuits I have built have usually worked.DeuceEFI wrote: I used the CEL recommended 50ohm resistor to ground on the input and 100ohm resistor on the emitter output, I tried various resistances on the emitter output between 100ohm and 5kohm per CEL's datasheet and the larger the resistance I used past about 220ohms, the waveform on the output degraded to nothing but framing errors on the LA and a badly formed sawtooth waveform on xoscope.
I am convinced that you dont need the emitter resistors at all, just connect them to ground as per the RavAGE schematic, just like the cathodes of the LED's are!
If you put it back in the same configuration as RavAGE, I would like you to change the 2K4 resistors to something low like 270R. This will allow 18.5mA to drive the internal opto diodes (LEDs). I think they need to be driven harder, as the existing 2K4 resistors only allow 2.08mA of diode current. (assume supply is 5V)
you can go as low as 220R, but I personally wouldnt go any lower. It should damn well work with that amount of current!!!!!!
Then we can work our way up with resistance and find our "sweet spot" in terms of amount of current required to drive the opto!
Any chance you may have gotten a crook opto IC? I cant open yet/havent looked at, your log stuff yet. But did you scope both opto's or just one?
