But lots to do before that.
Spudmn's Puma board build
- Spudmn
Re: Spudmn's Puma board build
Very cool. I can’t wait to hook up a switch to the clutch and hack some code to make a launch control system and flat shifting.
I can add that for you in 30 mins or so, just let me know, it would be my pleasure. I've been looking forward to adding features for a LONG time :-) IE, don't steal my icing/thunder! Otherwise I might have a tantrum, like a child :-)
- Spudmn
That's fine with me. You code it and I will have fun using it.Fred wrote: IE, don't steal my icing/thunder! Otherwise I might have a tantrum, like a child
I will let you know when I get the switches hooked up and I need the code.
That's fine with me. You video it and I will have fun watching it.
^ reuse. :-)
^ reuse. :-)
- Spudmn
I have just started to play with MegaTunix. I have an event coming up and I want to try a number of different advance curves. My plan was to set up the different curves and export them from MT. Then on the day I could import them and update the ECU. MT is not working as I expected it to. I thought that export would have sent the tables to a file and I could import a different one.
Am I doing some thing wrong.
My fall back position will be to flash new hex files with different curves.
Latest MTX built from source? From latest on recommended thread? Or latest from Dave?
You can export each table individually or save the entire config from the menu. For your purposes, single table export will be the clear winner as loading it will be WAY quicker and it's human readable and thus tweakable on the day with vi or whatever.
People say that both work. I've not personally tried either. I expect that you're doing something wrong.
He recently started work/destabilisation on project style use. So you might find the files in mtx/projects/default/* or similar.
Your best bet re tuning is to develop a WOT curve that doesn't knock with your normal fuel by gradually increasing timing and doing WOT runs while listening for pinging. Make sure the engine is racing-hot while doing this, or do it at normal temps and then pull a degree or two everywhere.
Are you doing of have you done a "DET can" setup? (bolt, tube, modified earmuffs)
PS MT traditionally means MegaTune... :-)
- Spudmn
I will update and try again.
Yeap I was going to do WOT curve to start with.
I had never heard of this so I had to Google it. Looks interesting I will have to have a look it to this.Are you doing of have you done a "DET can" setup? (bolt, tube, modified earmuffs)
OppsPS MT traditionally means MegaTune...
- Spudmn
OK tried latest from git://github.com/djandruczyk/MegaTunix.git and now the export is working as I expected.
If you have a good crash free experience with it, let me know the exact hash and I'll test it myself and promote it to recommended.
- Spudmn
I have been working on my first Puma this morning.
It has a nice stable 16 Mhz. So far every signal around the Xtal matches up aganst the working Puma.
I still don’t have any output on the Uart Tx. I am waiting on a replacement FTDI chip today and I will try and test the boot loader.
If I still don’t have any luck I will build a USBDM viewtopic.php?f=37&t=1696
The only thing left to try is the software.
