I believe so, yeah! Custom engineered, but very cool. Hence I'm interested in pursuing it.
Jamies Fe3 Van Project
Re: Jamies Fe3 Van Project
progress
Il be getting the fe3 ready for a test fit in the weekend
Sweet, get someone to snap a pic of the grin that appears on your face when you drop it in for the first time ;-)
This was my grin moment (no pic of the grin though) :
http://i50.photobucket.com/albums/f323/ ... 0_3498.jpg
the first time the fe3 gets dropped in the van there will be a beer in my hand aswell as a look of joy
hey man was it a pain pulling the motor through the top? did it catch on many things or did it come out pretty easy?
it came out easy enough just a bit of fiddling with getting the sump over the firewall but it you gave a nice short chain over the motor it easy
oh sweet man. because ill probably doing that soon myself so i thought maybe itll be easier to just pull it from out the top instead of dropping it down.
G'day James, looking forward to seeing that Fe3 going into the van. I will be starting on my van project soon, the intake manifold will be the first on the list, fabricating up something that fits nicely in that area.
No doubt you will also have some head scratching to contend with, especially for the rear of the motor. The cas system that Fred was talking about and pictured in this thread certainly would be ideal, as much room as possible is required in that area. I still think an inspection plate of some kind is called for though, for easy access to coolant hoses/ piping.
I have been told modifying the engine mounts by dropping the motor one inch, or 25mm, to the metric minded will help give clearance for the seats.
I am going to MS this project as well as I have a 2 litre sohc carb set up.
Good luck on your project and I look forward to your progress.
Barry
Barry
cheers barry
I plan on making an inspection plate to allow room for to fit the thermostat housing and modified dizzy, based on this
I am getting a carb fe bottom end from the wreckers tomorow so I can swap the engine mounts over to the fe3 and have a test fit to see if the mounts do have to be dropped.
Get a thread started and show us what you have to play with and if you want general econovan/bongovan info sign up to the http://www.rangimods.co.nz forum
I picked up the bottem end from the wreckers yesterday and stripped off the alternator,powersteering and engine mounts.
They all bolted up to the fe3 block fine, the only problem I found is that the fe3 runs ribbed belts where as fe carbs run vbelts so Iv got to swap the pulley wheels on the alternator and p/s over to fe3 items.
The sump and oil pickup off the fe carb block wont go straight on as the crank braces foul both of them, its nothing major though just a little cutting and welding to make them fit
