Wideband Tailpipe Sniffer Tube Design - Input Wanted
Re: Wideband Tailpipe Sniffer Tube Design - Input Wanted
SLC PP2.1 is here in my living room :-)
https://twitter.com/FredCookeNZ/status/ ... 2893647872
Hentai
Post by Hentai »
main issue I have dealt with the tail pipe sniffer is usually the output is wrong. Generally it will be leaner, but never a set amount because of the difference in piping under cars. I don't trust them. The chance is very high if its on any modded car that the output is wrong.
That's only going to be true if the exhaust has leaks or there is reversion. Which are you suggesting? Aside from a higher chance of those, you should expect a more honest reading as combustion is more complete further from the engine.
DelSolid
Post by DelSolid »
Here is the Innovate patent on their tailpipe clamp and bung extender designs and the theory behind them. Interesting reading if you are into that stuff, and if you are reading this thread I am guessing you are.
US20050160840.pdf
(998.52 KiB) Downloaded 1487 times
1969 Plymouth Satellite Wagon with a 440 & TF727
1929 Ford Roadster with a 2JZ and a T400, GT47, 1,100WHP, 240+ MPH
1930 Ford Roadster with a 42 Merc Flathead with triple Holley 94's. Major work in progress
I work for AEM but am not here schilling for them. Nothing I say is official.
