Jaguar 0.6-alpha Assembly Guide
DeuceEFI
Re: Jaguar 0.6-alpha Assembly Guide
Post by DeuceEFI »
The circuit works the same with the 1 ohm 10 watt resistor or without the resistor between the 12v battery and the TPS-5v output. I only snapped the one (blurry iPhone auto focus failure) photo during my tests of the over-voltage clamp circuit.
E4ODnut
Post by E4ODnut »
Andy,
I think I'm ready to install the serial monitor program, whatever that is. Problem is the BDM you sent me has a 6 conductor flat ribbon cable instead of the double header pins as shown in the photo. What should I do to make it work.
Also, I'm not clear on the process after it is connected. I have the hack down loaded, but then what?
I also have Fred's bench test firmware downloaded but am not clear as to the steps in loading it on to Jaguar
Robert
^ Solved, in person! :-)
E4ODnut
Post by E4ODnut »
I'm afraid I'm going to need some more details on how to get the serial monitor software installed.
I installed the 6 pin header on Jaguar, plugged in the DBM and connected it to my PC, which in turn looked for driver software to install, without success. Next step?
Robert
"my PC" = Windows? I can not help you, if so. I've used it extensively on Linux, but never once on Windows.
E4ODnut
Post by E4ODnut »
Well, I guess that brings everything to a screeching halt.
Robert
This is Peter
On my windows machine I have a program from freescale specifically for loading the SM.
http://www.freescale.com/webapp/sps/sit ... _Tools_Tab
On this page under the Hardware Development Tools - Programmers there's a link called BDMPGMRDP256FW, and I think it's the right one but I don't have windows box here to verify it. So you might have to download a few other packages to find the right one. If it is the right one you'll want to use the verify option and load it as many times as it takes to get a successful load, because I had an extra byte on one of my SMs.
pishta
Post by pishta »
On another note, is pure rosin flux safe to keep on your boards? It says its "completely non corrosive and safe for use on all electronic applications". Looks and feels like tree sap, like...'cause it is? And PLEASE tell me the smaller dot in the lower left corner of the chip (as compared to the nomenclature writing) denotes pin 1? So the chip reads correct when all the other horizontal script on the board is upside down? please please please!!!! :oops: :oops: :oops:
pishta
Post by pishta »
Fred wrote:This is Peter
Nope, thats just the firmware package. I believe we need the Win driver for the USBDM so we can communicate with it...its a windows thing...;-(
Yes, the small dot denotes the positioning, and IIRC the text IS upside down. Andy needs a FAQ for that, or perhaps a new footprint too, to reduce confusion?
As for the flux: viewtopic.php?f=9&t=1952
Alcohol is your friend, one way, or another :-D
