So, getting to that, why do you not like using the MAT? Just because it is so prone to error? (That's ENTIRELY reasonable)
My question is, if you had a 100%, idealized MAT, with no radiative coupling, no heat soak, it just somehow knew the exact temperature in real time of the air in a particular place.... Why would you mount it outside of the manifold?
I would think you'd want the MAP and MAT to be in the same place at the same time, since really you're just counting molecules/sec entering the engine.
If it were me, I'd have four flow meters, one in each runner, and do my fuel and timing based on that, with direct injection.
 To quote our beloved Jean-Luc:  Make it so.
