Innovate LC-1 problem
Re: Innovate LC-1 problem
OK! If that's true, then I concur with your advice! :-)
wrcbfmr
Post by wrcbfmr »
ugh, ffs fred, yes OUTPUT TO ECU, thought that was pretty clear... go get a job and stop being so anal :-P cheers dan, yeah i need to go hook it up to the lappy (sorry fred, laptop) and have a look whats going on on that side of things.
It's not clear unless it's clear. Would you rather someone less anal had built that box for you? :-p And refer to my first post, in which I told you to hook up the software to it and check everything ;-)
wrcbfmr
Post by wrcbfmr »
lol that was the plan but im only home on the weekends so shall do that tomorrow and have a look. possible the sensor needs recalibrating for some reason or other, soon find out
m2cupcar
Post by m2cupcar »
Was this resolved? Have the same problem with an Innovate SCG-1 controller and LSU 4.9 sensor.
Dan is far away on a boat, and other Dan doesn't visit the forum anymore, so I doubt you will get a response. Just FYI.
