SM Re-Development in GCC + Customisations/fixes
Re: SM Re-Development in GCC + Customisations/fixes
Work has begun! I got 6 commits in earlier tonight on the roof of the car while enjoying the view of the Barcelona skyline. The next 6 will be harder, but still pretty easy with some luck. Fingers crossed.
I got another commit in on this tonight, next commit should yield a binary of what we already have, but repeatable, and as a source base point.
Getting close now!
GAS seems to be crappy, or I don't know how to use it properly. Maybe I need to patch binutils to work better.
from "bset something, somethingelse" I'm getting the following instruction:
1C 00 0C 01
however it should give:
4C 0C 01
because the high bytes of the "16 bit operand" are zeros and it's static, not dynamic. 25% code space saving there, cycle count is equal, though, so no faster.
I want a resolution for this.
Just changed the operands to literal 8 bit, and no better behaviour. I think GAS simply doesn't support this, or have the sophistication necessary...
1C 00 0C 01
4C 0C 01
GAS definitely has the opcodes in the binutils source, it just won't use them for some reason. More tomorrow.
if (format & M6811_OP_DIRECT)
continue;Thanks Sean for your help!
This new serial monitor s19 removes the requirement for a PNP hack for FTDI devices. Other side effects are not tested, however it's strongly likely that it doesn't have any for our application. I suggest using this on new hardware as an interim solution until I can engineer a proper solution. Idea (of hacking the binary directly) by Sean, all reverse and forward engineering by yours truly. This is disgusting, but you'll like it, so enjoy.
- seank.hackers.special.by.fred.s19.zip
- Dirty dirty hack :-(
- (2.43 KiB) Downloaded 1255 times
I have an almost perfect match on the serial monitor of old from code now. Much of the problem was this situation:
Each of those instructions is real if you remove the d which stands for direct. Unfortunately, as illustrated above the direct instructions are _never_ used in GAS.
Another problem is that the source I had wasn't complete. It was nearly complete, though.
I'll make my almost perfect match perfect tomorrow, at which point I have a solid base line for both the SM and binutils testing/dev.
Solid progress tonight! :-)
dbset = 0x4C
dbclr = 0x4D
dbrset = 0x4E
dbrclr = 0x4F
dldab = 0xD6
dldy = 0xDD
dldaa8 = 0x86
dldaa9 = 0x96
dstaa = 0x5A
dstab = 0x5B
dstd = 0x5C
dsty = 0x5D
dcmpa = 0x91Another problem is that the source I had wasn't complete. It was nearly complete, though.
(03:00:11) Fred: [gnu-binutils bac1ae0] This, ugly as it may be, builds EXACTLY the serial monitor from the firmware lib dir. With time and binutils tweaks I'll make it clean, then I'll make it behave as it should.
(03:00:11) Fred: 3 files changed, 555 insertions(+), 148 deletions(-)
3am, and I beat the bastard fair and square! :-)
Binutils fixes are next on the menu for this thread.
http://issues.freeems.org/view.php?id=668
Gave it an arbitrary target version. I might make sub-issues with each feature/change etc.
Let's see if we've got a spy, or not. Fuck you, James Murray!
