View unanswered posts | View active topics It is currently Sun Mar 24, 2019 5:37 am
Reply to topic  [ 161 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 17  Next
Fred's FreeEMS Powered 89 Ford Courier w/ Holset fed FE-DOHC
Other people that aren't stuck in England have received thier cam gears :
That's the same colour as mine will be. It matches my air filter and plumbing nicely :-)
I feel very rice, but it will be worth it when the custom cams arrive (not yet ordered).
Fri Dec 19, 2008 4:44 pm
The diff works :
http://www.youtube.com/watch?v=WMXSFjf-fyQ
:-) Awesome work!
Smoking tyres at 11,000 miles range, sweet.
Sat Dec 20, 2008 12:38 am
Sat Dec 20, 2008 12:44 am
I need to ditch those corolla arms :
http://i50.photobucket.com/albums/f323/ ... 0_4434.jpg
http://i50.photobucket.com/albums/f323/ ... 0_4435.jpg
I filled my ute mounts with windscreen urethane and it does make a big difference to stiffness, however it does not make them any stronger. What happens if you drive the car hard is that LHS (drivers side for you yanks) side of the engine tries to lift up under hard accel and eventually succeeds by ripping the rubber in half. There is no good solution to this bar replacing the mounts with a different design.
Here are some pics :
Should be pretty easy to fab up something similar. Key point is that they are retained by steel, so the rubber can wear out and your engine won't come out through your bonnet like it will with the stockers (or even mazdaspeed miata ones).
I broke 3 ute mounts with 80hp and one skyline mount with 150hp. Hence the 400hp ute is reinforced, but the corolla arms I used are heavy and ugly and in the way. They need to go and this is the solution.
Sun Dec 21, 2008 8:01 pm
I don't have this in my possession yet, but these should be shipped to NZ at some point in the nearish future. The will allow me more room to use a larger filter and/or adapters and what have you for oil cooling if I end up needing it.
Mon Jan 05, 2009 10:50 pm
http://www.youtube.com/watch?v=0P7UvLRj_r0
West Aucklanders... just can't be trusted to store a perfectly good van quietly! ;-)
Thu Feb 12, 2009 12:06 am
Here you go.
6" to 4" for yah.
http://cgi.ebay.com/ebaymotors/BLOX-ALU ... ccessories
BenFenner's 1994 Black SE-R
Wed Oct 28, 2009 1:12 pm
Are you insulting my toilet-plumbing-PVC inlet??? Bastard...
Wed Oct 28, 2009 3:57 pm
Not at all. Plenty of top-notch cars sold in dealerships and raced around the world use plumber's PVC pipes for their intakes.
Wed Oct 28, 2009 5:12 pm
May I present, the front! :
Dead: [ img ]http://i50.photobucket.com/albums/f323/fredio54/TheRedTruckFront.jpg[/ img ]
Tue Nov 17, 2009 11:14 am
