Ben's messing aroung with FreeEMS-Tuner code
Re: Ben's messing around with FreeEMS-Tuner
Okay I got the payload hex display thingy finished. I'm going to try and figure out how to post the code using git tonight. For now you get a screen shot and the file sin *.zip form.
Changed files:
gui/commsDiagnostics.py
protocols/FreeEMS_Vanilla/0_0_17.py
I used extra data to simulate that screen shot. You're not going to be able to reproduce the screen shot taken below. Characters that don't translate to ASCII are displayed as an underscore. Hex rows are padded with asterisks.
Edit: Oh, the code is really bad by the way. I'm still learning Python and I know a lot of it could be cleaner. Aaron, do what ever clean-up you'd like.
Changed files:
- Files.zip
- (5.17 KiB) Downloaded 677 times
Don't be afraid to make it all a bit wider as this is just a debug tab at the end of the day anyway.
What I was trying to say is this :
In the flags column instead of the value 17 which is meaningless even to me and I set the flags up lol.
IsProto : 0
HasAck : 0
HasLength : 1
HasAddrs : 0
IsNack : 0
spare1 : 0
spare2 : 1
spare3 : 0
Perhaps upper case ON and OFF or YES and NO instead? or perhaps 0 and 1 are best :-)
- sry_not4sale
Good stuff ben
You say that now. Then you take a look at the source. =Psry_not4sale wrote:Good stuff ben
Edit: By the way, it looks like I started with some older code, so be careful merging my stuff in with yours if you do it manually. I'll try to update my repository and then push the changes later on. We'll see how it goes.
Committed the changes to my repository. Tried to push the changes with no luck.
Can you not "pull" from me? Isn't that how this is supposed to work? =/
I don't even know if I trust myself enough not to mess things up if I am given rights to write to the master repository.
I'd love to get it so you (Aaron) don't have to do so much work everytime I send in a change. Let me know what I should do.
Re: Ben's messing aroung with FreeEMS-Tuner code
Fred has pointed out a problem with the red button in my screen shot. It should say "(ECU Hard Reset)" not "(ECU Reset)". Somehow either that change never made it into the master repo, or I've fudged something up. Aaron, seems like a real quick fix for you if it is indeed wrong in the master repo, which I'm betting it is.
- sry_not4sale
Hey Ben,
Can you PM me or email me your SSH public key? Then I'll give you push access to a development repo. We can have a branch each, and I'll just cherry-pick stuff into a master branch and then the distribution repo.
People can pull from your branch if they want something asap, and you can just merge with the master branch to make sure you have all my changes also.
Will write up some how to's once you generate a key and I set up the branches
Cheers,
Aaron
Cheers,
Aaron
Sweet :-)
Ben, from the docs :
Header Flags
Bit 0 - Payload type (protocol/firmware)
Bit 1 - Acknowledgment valid and/or required
Bit 2 - Acknowledgment type (-ve/+ve)
Bit 3 – Has Addresses
Bit 4 – Has Length
Bit 5 - Firmware implementation specific
Bit 6 - Firmware implementation specific
Bit 7 - Firmware implementation specific
And the code :
Aaron :
Won't that create more work for you, or at least keep it the same?
I guess a bit of communication will keep it minimal though, just a thought.
Header Flags
Bit 4 – Has Length
And the code :
/* Header flag masks */
/* Always has flags (obviously) */
/* Always has payload ID so no flag */
/* Always has checksum, so no flag */
#define HEADER_IS_PROTO BIT0
#define HEADER_HAS_ACK BIT1
#define HEADER_IS_NACK BIT2
#define HEADER_HAS_ADDRS BIT3
#define HEADER_HAS_LENGTH BIT4
#define HEADER_USER_BIT_A BIT5
#define HEADER_USER_BIT_B BIT6
#define HEADER_USER_BIT_C BIT7
