depending on price and features I may want a few cars worth.
88' Porsche 924s 4<-4cyl
92' Alfa romeo <-V6cyl 60degree
90' Nissan 240<-4cyl
XX' Gm series II L67 <-V6cyl 90degree
99' Miata <-4cyl
maybe few lawnmower engines worth too, but we'll see a little latter.
FreeEMS revision A version 1 first edition PCB feeler
comrade904
- TO220 - Visibile
Re: FreeEMS revision A version 1 first edition PCB feeler
- On board IGBT ignition drivers - Preferred but can handle them being in the same case (I dont want multiple boxes)
- On board low Z injector drivers - Must for me, I dont want to replace my brand new Racetronix 120lb injectors and resistors are a turn off and generally suck overall IMHO
- Thermistor self heating prevention :-p
- NO thermistor self heating prevention
- Current feedback circuitry on injectors - Probably yes
- NO current feedback circuitry on injectors
- ONLY SMD components - Slightly opposed since some SMD look like a bitch to solder but ive never tried so I dont know first hand
- ONLY TH components - Neutral
- SMD components supported - Neutral to positive, I can handle some SMD
- TH components supported - Neutral, I like TH but they do make for a bigger board
- X primary fuel channels required/preferred - Require 4 Low Z
- X ignition channels required/preferred - Require 2 (wasted spark), 4 would be great for future "just in case"
- X auxiliary low current low side drives preferred and required OnOff / PWM - Boost control!!! Water injection solenoid control would be nice, probably two so that there can be an IC sprayer. Water inj/IC sprayer can be general outputs though
- X auxiliary high current low side drives preferred and required OnOff / PWM - Nothing jumps to mind beyond a way to control a pump for water injection, so probably 10-15 amps for a Shurflo... A low current relay output would be ok here as well
- How many boards? - Ill probably buy 2
