View unanswered posts | View active topics It is currently Fri Mar 22, 2019 9:06 am
Clockwise Hall effect 4/2 DSM/Miata/MX-5 pattern CAS
I happen to be rather envious of that particular vehicle! Though if I had it I'm not sure how long it would be before the cylinder head was swapped onto the Amazon.
Fred wrote:
[...] how did you come up with the *relative* timings of the inner/outer sections without that or without spinning it and scoping it?
I wish I could say I scoped it, that would have been much cooler. I wired the CAS up, fixed a ~300mm dia cam/crank timing wheel to it, and rotated it very slowly.
Fred wrote:
if you want to duplicate work for your own edification, look for the lines around 'correctEvent' and modify those if statements and contents thereof.
Thanks. I'll see if knowing where to look helps me out :)
Sat Jun 09, 2018 4:29 pm
OK, your method of figuring out the angles should be close enough at worst. I'll push my work up later today (probably, though very slow start, up at 1pm... sigh) and you can compare notes with what you did.
I got the bulk of it changed to be correct last night, but didn't suss out either the old or new variant of the blue tick. Maybe it was the wine. :-p
Sun Jun 10, 2018 2:12 am
Didn't happen, will try to get it done tonight. Sorry.
Sun Jun 10, 2018 8:56 pm
No wozza mate.
Sun Jun 10, 2018 9:48 pm
Ended up writing some corner-case fixes for the tip in enrich code that someone was having some drama with. He can work around it with data changes, but I wanted to serialise my thoughts ASAP. And now it's midnight. Sorry again. Maybe Tuesday night is *your* night :-)
Mon Jun 11, 2018 12:42 pm
Doing extra hours at work, and getting through chores at home, didn't touch any of the three software goals I had tonight. Maybe tomorrow will differ. Still waiting on your attempt, though :-)
Wed Jun 13, 2018 1:02 pm
Code complete! But...
Your diagram is wrong. Tsk tsk tsk. Please leave the old diagram online, provide a new one with red whereever black/blue occur, and post it below this and I'll link your original as EDIT: Wrong: http... and replace the old one with the new one. Okay? :-)
Basically, the two sequences of unknowns are absolutely identical in sequential state, so it's not possible to determine sync from either of them except by recording primary unknowns seen and on the fourth declaring sync. BUT, that is of SUPER minor benefit as the next positive sync is just after it. I won't bother. Or will I? Not today, anyway. Proof:
Code pushed! Notes:
Combined your two UI commits and gave them a decent comment, ish.
Fixed the logic up.
Added some infrastructure to allow easy build of it.
Tested build works okay on my box (it compiles, it must be okay... ;-))
do this:
git remote add fred-github git@github.com:fredcooke/freeems-vanilla.git
git fetch fred-github
git checkout mazda-backwards
profit
Sorry for the delay...
Wed Jun 20, 2018 11:38 am
That is the business. Thank you. And sorry for the false lead with the diagram. Is this how you mean to have red replacing wherever black/blue were?
Fri Jun 29, 2018 9:43 am
You're welcome, and no apology necessary at all. My pleasure. :-)
Keep that one there, and add another with either:
10, 0, 1 black and 2 blue
OR
10, 11, 0, 1 black, 2 blue
As technically that could happen and save a fraction of a second in starting time. I don't think checking 11 is necessary at all, hence the former, but you could maybe mark 11 grey to indicate optional/pointless usage slash being part of the sequence.
That leaves 4, (5), 6, 7 as a false sequence (red is fine) that will be counted up to and then overridden by 8 occurring first. Whereas the identical sequence as listed above for black/blue will end with the count reaching the blue one and syncing before 3.
Make sense?
Sat Jun 30, 2018 4:36 am
Grey either looked too washed out or like black at a glance so I fancied it up.
Sun Jul 01, 2018 10:09 pm
