View unanswered posts | View active topics It is currently Sun Jan 20, 2019 9:35 am
Reply to topic  [ 161 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17  Next
Wiring is now completely no-go - but engine is back together except the radiator fan which wasn't working anyway.
Tweets:
https://twitter.com/FredCookeNZ/status/ ... 0973136896
https://twitter.com/FredCookeNZ/status/ ... 2146441216
https://twitter.com/FredCookeNZ/status/ ... 1753849856
https://twitter.com/FredCookeNZ/status/ ... 9280983040
https://twitter.com/FredCookeNZ/status/ ... 9441245185
https://twitter.com/FredCookeNZ/status/ ... 2531291137
Pics: TODO
Thu May 03, 2018 12:22 pm
Wiring wasn't the issue, connector in the cabin was. But I went ahead and ruined it anyway, then when I came to connecting the replacement wire, I found the issue. And no sooner had I done that than I remembered realising it was in the passenger footwell about a year ago. Forgot. Ruined super fancy wiring that Presto did years ago. Fail. Laugh at my expense at one of the worst hack jobs you've ever seen, and yet, she runs again:
https://twitter.com/FredCookeNZ/status/ ... 0230596608
https://twitter.com/FredCookeNZ/status/ ... 2398919680
https://twitter.com/FredCookeNZ/status/ ... 0562330626
Shame on me.
Fri May 04, 2018 12:53 pm
After the above, in the same clipped together condition, I took it for a decent test drive into the city with the Mrs and back again. Given the badly leaking water pump, that was the furtherest it had gone in a year or so, and also the first time anything had seen any kind of pressure as the pump was venting it efficiently. Net result, the internally corroded radiator sprung multiple leaks and was misting the air in various directions when I got home to check on it. Aside from that, it ran well. That was yesterday around noon or so.
Today was spent looking for a compatible radiator in a more modern vehicle, and retrofitting it in. Success tonight. Now it's all seeing lots of pressure that it's not seen in ages. Yet to properly test it as there was air in the system which bled out faster than water would have, but it's going to the supermarket in a while, so I'll report back after that and upload today's pictures then, too.
Wish us luck! Ultra dodgy cooling system and ultra dodgy wiring! We're gonna need it! :-D
Sun May 06, 2018 8:40 am
^ so much drama. So little happened. All fine :-)
Old pics:
https://twitter.com/FredCookeNZ/status/ ... 0321534976
https://twitter.com/FredCookeNZ/status/ ... 9147465733
https://twitter.com/FredCookeNZ/status/ ... 7021446144
https://twitter.com/FredCookeNZ/status/ ... 3389803520
https://twitter.com/FredCookeNZ/status/ ... 8822921216
https://twitter.com/FredCookeNZ/status/ ... 7178868736
https://twitter.com/FredCookeNZ/status/ ... 5503540224
https://twitter.com/FredCookeNZ/status/ ... 3062921216
TODO: photos
Wed May 16, 2018 8:41 am
Fueled up! 11.5 litres per 100km! Not bad :-) https://twitter.com/FredCookeNZ/status/ ... 5182725121
Sat May 19, 2018 9:11 am
Flat battery and solution: viewtopic.php?f=15&t=2719&p=44383#p44383
Coolant no longer water for the first time in years: viewtopic.php?f=15&t=2693&p=44385#p44385
Sun May 20, 2018 11:40 am
You know how I thought the engine was toast and I was thinking of replacing it and all that stuff... well, I was wrong. And happy about it.
2 years of driving it once a month or so and I'm dailying it again and start thinking and take a quick look and test and bingo, smooth running engine once again.
It's still smoky, and still drinks oil, but it's more or less okay aside from that. Hooray.
https://twitter.com/FredCookeNZ/status/ ... 0414558208
https://twitter.com/FredCookeNZ/status/ ... 7322354688
Might have to fit up my 15" wheels again, I think. Don't have the funds to fit up the 16" alloys and it looked a bit wrong on them anyway.
Wed May 23, 2018 1:47 am
Daily driving == twice daily jump starting. Updates from 3 weeks since last post:
https://twitter.com/FredCookeNZ/status/ ... 7357420545
Now, it's been referred to as a boat before, but not quite like this:
https://twitter.com/FredCookeNZ/status/ ... 2122115073
https://twitter.com/FredCookeNZ/status/ ... 6431853569
https://twitter.com/FredCookeNZ/status/ ... 0221496320
https://twitter.com/FredCookeNZ/status/ ... 5704507394
https://twitter.com/FredCookeNZ/status/ ... 1046635520
https://twitter.com/FredCookeNZ/status/ ... 9886643200
https://twitter.com/FredCookeNZ/status/ ... 4621115393
https://twitter.com/FredCookeNZ/status/ ... 6858997761
https://twitter.com/FredCookeNZ/status/ ... 0962628608
https://twitter.com/FredCookeNZ/status/ ... 6543617029
https://twitter.com/FredCookeNZ/status/ ... 4402176000
https://twitter.com/FredCookeNZ/status/ ... 6370803716
https://twitter.com/FredCookeNZ/status/ ... 3553311744
Fan manually wired up, cough: https://twitter.com/FredCookeNZ/status/ ... 6079471616
Can you tell I'm getting fibre in the next few days? :-D 20x increase up and down! :-D
Mon Jun 11, 2018 9:32 am
Still has clips holding the decimated loom together. Put the Jag back in it this evening, added two clips to connect the dots, cranked, nothing. Tried VR/Hall switches, nothing. Realised one wire had fallen off and the clip was touching another clip. Doh. May have cooked the Hall output! If so, that's going to suck badly to resolve given how rare these are. Will try again tomorrow, too late now to attempt to diagnose it.
Tue Jul 31, 2018 11:31 am
Tried again to get it started today, failed. No signal from the hall sensor when cranking. Damn it. No idea how to get a replacement. Terrible timing. Need the car out on the street and parked out of the way and it's dead in the water meaning pain/effort to move it and landlord annoyance risk until then. Doh.
Sun Aug 05, 2018 10:17 am
