View unanswered posts | View active topics It is currently Fri Dec 04, 2020 11:45 am
FreeEMS revision A version 1 first edition PCB feeler
This thread is to gauge interest in getting a FreeEMS PCB through a future bulk buy.
Please post in this thread if you are in principle interested in going in on a bulk buy of 10 or 20 of the initial FreeEMS PCB.
Discussion here : viewtopic.php?f=9&t=407
One post per person in this thread please.
If your interest is conditional upon various features please state that. Some things you may or may not care about :
  1. On board IGBT ignition drivers
  2. On board low Z injector drivers
  3. Thermistor self heating prevention :-p
  4. NO thermistor self heating prevention
  5. Current feedback circuitry on injectors
  6. NO current feedback circuitry on injectors
  7. ONLY SMD components
  8. ONLY TH components
  9. SMD components supported
  10. TH components supported
  11. X primary fuel channels required/preferred
  12. X ignition channels required/preferred
  13. X auxiliary low current low side drives preferred and required OnOff / PWM
  14. X auxiliary high current low side drives preferred and required OnOff / PWM
  15. How many boards?
Also state how many you would be willing to purchase to make up numbers if required.
My requirements are :
  1. Don't need - either
  2. Don't need - either
  3. Don't want - prefer not, but either
  4. Don't care - prefer not, but either
  5. Don't want - prefer not, layout dependent
  6. Undecided, layout dependent
  7. Won't buy
  8. Will buy
  9. Don't care - either
  10. Required
  11. 4 primary fuel channels prefer 6
  12. 4 LOW LEVEL ignition channels prefer 6
  13. prefer : 2 on/off for relays for fans no low current pwm
  14. prefer : 2 high current PWM for boost/idle, no high current on/off
  15. 1 or 2 depending on how much I like the design
Unused injector channels can drive high current on/off stuff and unused ignition channels can drive low current and/or high current on/off stuff. PWM outputs would need to be just for that only.
Quote this message and edit away all the stuff except the main list and then run through it changing the words to your thoughts on the item.
To summarise for me :
1 or 2 boards
Must have 4 high Z fuel channels
Must have 4 low level ignition drivers
Must have through hole component layout
If the current feedback isn't dropped and it makes a mess of the layout I may be not be interested. Would prefer it wasn't there.
It is assumed that basic stuff like good power supplies and sensor inputs including at least 2 VR inputs, analog wbo2, air, water, tps, map, atmo, etc will be included by default. You don't need to worry about that sort of thing. If there is something you really care about that isn't on the list, please mention it clearly.
State your interest here!! :-)
It will be a little while before it goes to be printed, and a little while before we have usable code for it too this just a feeler to see what people are and aren't interested in buying and testing/using.
Fri Aug 22, 2008 10:28 pm
Post Whore!
  2. On board low Z injector drivers YES
  9. SMD components supportedYES
  11. X primary fuel channels required/preferredYES,2/4
  12. X ignition channels required/preferredYES,2/4
  13. [fred was here]
  14. [fred was here]
I'd also:
NEED: 1-WBO2, drive for 1 relay (fans)
Want STRONGLY: Knock Sensor In, Drive for 2 relays (total), 2 PWM soleniods
Want: EGT in, Drive for 3 relays (total), RPM based Knock Sensor decoding (I have a lead on some circuits for this)
Wish - ooodles more, 4 secondary injectors, etc etc.
Fri Aug 22, 2008 11:27 pm
Profile ICQ YIM
  1. On board IGBT ignition drivers x 6
  2. On board low Z injector drivers x 6
  3. Thermistor self heating prevention No Way!
  4. NO thermistor self heating prevention Correct
  5. Current feedback circuitry on injectors No Thanks
  6. NO current feedback circuitry on injectors Correct, waste of PCB real estate sorry
  7. ONLY SMD components Inflexible
  8. ONLY TH components Bulky
  9. SMD components supported Yes
  10. TH components supported Yes
  11. primary fuel channels required/preferred 6
  12. ignition channels required/preferred 6
  13. auxiliary low current low side drives preferred and required OnOff / PWM 3xPWM, 4xon/off
  14. auxiliary high current low side drives preferred and required OnOff / PWM 2
1 main PCB preferably with 88 way motronic connector footprint and Qty of 2-4.
Also:
WBO2 input is a must
Cam hall sensor x 1
CAN comms would be nice
Preferably all High current drivers to be TO220 or TO3P SMT begrudgingly.
Sat Aug 23, 2008 12:40 am
1N4001 - Signed up
  1. On board IGBT ignition drivers at least 1
  2. On board low Z injector drivers no preference
  3. Thermistor self heating prevention required
  4. NO thermistor self heating prevention Isn't this the same question twice?
  5. Current feedback circuitry on injectors yes please, but not a deal breaker
  6. NO current feedback circuitry on injectors again same question right?
  7. ONLY SMD components no preference
  8. ONLY TH components no preference
  9. SMD components supported no preference
  10. TH components supported no preference
  11. primary fuel channels required/preferred at least 1, no preference about more
  12. ignition channels required/preferred 1
  13. auxiliary low current low side drives preferred and required OnOff / PWM no preference
  14. auxiliary high current low side drives preferred and required OnOff / PWM no preference
  15. How many boards?1-2 main PCB's
My interest is around small engines, as they are good platforms for experimental purposes.
Sat Aug 23, 2008 1:19 am
I have posted in some of the discussions.
Preferences:
No. Not desired for this install, but please keep them in the design.
No. Not desired for this install. Not wanted in general as it complicates things in a revision A 'base system'.
No. Not desired or necessary in general for EFI, IMO.
Yes. Preferred embodiment for 'base system'.
No, please. Not desired as for 'base system' not necessary to consume board and complicate drive circuitry to get this info. Easy enough to do as daughter if necessary. Please, walk comes before run.
Yes. Preferred embodiment.
No. Old eyes and too many possible problems to debug over internet.
Yes. For all passive devices, the 'TH plus SMD' trace layout looked good to me.
Yes, Many nice FETs and IGBTs are avail in larger, easy to solder packages (dpak). That said, I am also in favor of the vertical to220 install geometry if devices are avail.
Yes, must.
4 fuel channels
4 ignition channels (plus cam and crank inputs both hall)
1 tachometer output
3 high current drives in addition to Fuel pump (PWM idle, PWM Boost, PWM ELCD)
1
Additionally I wish for 2 inputs (on/off)
A/C on, clutch engaged/disengaged
Sat Aug 23, 2008 6:52 pm
  1. Prefer at least 1.
  2. Prefered
  3. No
  4. Yes
  5. If space is available
  6. Doesn't matter
  7. Won't buy
  8. Will buy
  9. Don't care
  10. Required
  11. 4 primary fuel channels prefer 8
  12. 4 ignition channels prefer 8 either low or direct drive
  13. 1x as many types of outputs we will have
  14. 1x as many types of outputs we will have
  15. 1 for testing
Aditionally, 2x analog inputs 2x digital inputs
Sun Aug 24, 2008 5:11 am
  1. On board IGBT ignition drivers Prefer not
  2. On board low Z injector drivers No preference
  3. Thermistor self heating prevention :-p Prefer not
  5. Current feedback circuitry on injectors Not necessary
  7. ONLY SMD components Not on the initial release!
  8. ONLY TH components Prefer not
  9. SMD components supported Would be nice
  10. TH components supported OBviously
  11. X primary fuel channels required/preferred 4 required, 6 preferred
  12. X ignition channels required/preferred I can do with any number over one
  13. X auxiliary low current low side drives preferred and required OnOff / PWM 4 required 6 preferred on/off, no PWM
  14. X auxiliary high current low side drives preferred and required OnOff / PWM 4 required, 6 preferred PWM, no on/off
  15. How many boards?2
Plus 4-6 additional analog inputs and 4 digital.
Sun Aug 24, 2008 4:35 pm
1. On board IGBT ignition drivers OPTIONAL
2. On board low Z injector drivers OPTIONAL
3. Thermistor self heating prevention NOT NOW
4. NO thermistor self heating prevention NOT NOW
5. Current feedback circuitry on injectors NOT NOW
6. NO current feedback circuitry on injectors NOT NOW
7. ONLY SMD components :no preference
8. ONLY TH components :no preference
9. SMD components supported :no preference
10. TH components supported :no preference
11. X primary fuel channels required/preferred 8 required
12. X ignition channels required/preferred 8 required
You snooze, you lose!
Sun Aug 24, 2008 7:26 pm
Profile YIM
  1. On board IGBT ignition drivers not needed
  2. On board low Z injector drivers not needed
  3. Thermistor self heating prevention bare hands
  4. NO thermistor self heating prevention yup
  5. Current feedback circuitry on injectors sure, why not
  6. NO current feedback circuitry on injectors meh
  7. ONLY SMD components not on the first board
  8. ONLY TH components bleh, but yes.
  9. SMD components supported dont care
  10. TH components supported dont care
  11. primary fuel channels required/preferred 4
  12. ignition channels required/preferred 4
  13. auxiliary low current low side drives preferred and required OnOff / PWM 2-4ish?
  14. auxiliary high current low side drives preferred and required OnOff / PWM unknown
  15. How many boards? 2 maybe
Mon Aug 25, 2008 12:35 am
Profile YIM
Just a reminder that the discussion for this is here :
Please place your comments etc there to keep this clean and pure :-)
Tue Aug 26, 2008 7:47 am
