View unanswered posts | View active topics It is currently Sat Feb 29, 2020 12:17 am
Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
My open source Wideband Controller, SLC Free
JHC, you can almost make a DIY 3D printer for that! This should be Fred's next project...http://www.instructables.com/id/Make-a- ... led-parts/
or just buy this...Image
http://www.mpja.com/350in-X-137in-X-118 ... 6283%20BX/
Sat Jun 07, 2014 8:55 pm
TO92 - Vaguely active
I think you will find the box you just suggested is too small inside to fit the pcb. :|
There are larger ones available of course. Cheap on Aliexpress or Ebay :)
Jeremy
Fri Sep 19, 2014 7:12 am
Hello ! This project is now closed or has become completely commercial ? All files for the repetition of the device removed ? :(
Sat May 23, 2015 1:32 pm
you mean these files, on his site, under "Support / Software and Documentation", and linked to from his SLC product page? :roll:
TTR Ignition Systems
Thu May 28, 2015 12:54 am
Yes. Perhaps they are. Let me see . Thank you !
As a kind of looked up and not for the first time on this forum before I enjoyed.
Thu May 28, 2015 6:13 am
I just could not find the information ... I have the device interface to connect to a PC via USB or COM-port?
Thu May 28, 2015 7:08 am
Yeah, these?
http://www.14point7.com/products/slc-free and the documentation as posted above can be found here http://www.14point7.com/pages/software- ... umentation
Fri May 29, 2015 11:15 pm
toalan wrote:
You can get the source files here, https://github.com/toalan/14Point7.com_SLC_Free
I release this project it under GLPv3.
SLC Free only supports the Bosch LSU 4.9 sensor
There is a closed version that only supports the 4.2
Are there any plans to make 4.2 edition open? I know the source code is still available at your website, but I am wondering if you would be willing to ask questions on the code / add more comments into the code?
http://forum.diyefi.org/viewtopic.php?t=2070 http://www.rusefi.com
Thu Jun 11, 2015 4:57 pm
What acceptable alternative to the CY8C24423A-24PXI is there?
In my travels for that chip, I'm reading on sites to source that chip that is No Longer Available?
Sat Jan 16, 2016 12:27 pm
The 28-pin DIP (through-hole) -24PXI is definitely "End of Life"; Digikey has 46 and won't order them past the 6th of July. Mouser has >1000 on the shelf, so there's still time to order some in.
The 28-pin SOIC (SMT) -24SXI is apparently still going strong, and is the easiest of the SMT IC packages to hand-solder. The 28-SSOP -PVXI is also still in production, and can also be hand-soldered (with a little more care).
If you are working with a pre-designed board that uses the DIP package, SOIC-to-DIP adaptors are readily available.
Mon Jan 18, 2016 11:29 pm
