Open Source LSU4.9 Wideband Controller
Free Open Source Hardware discussion forum. Post your Free Open Source hardware projects here!
Re: Open Source LSU4.9 Wideband Controller
Re stoich, leaner, and oscillations, the OEM ECU does that to help the cat work... oscillating back and forward all on one side of stoich is totally useless.
Hell Fire
Post by Hell Fire »
I've added an Arduino Uno based board to the sketch, I probably still have too many non-Arduino libraries included (Teensys kit installs a bunch of them), but I can get the ATmega328 + crystal from the local Jaycar for $9 or something, preprogrammed with the Arduino bootloader on it. I haven't done a schematic up for it specifically, but the basic circuit is the same (although I think I've added the 100k tying 5v and PIN_VS as per toalans suggestion).
If you've got a form of ISP, you can probably do this circuit up a little cheaper, but this thing has been doing the narrowband feedback for my stock ECU since midday Sunday, and is being daily driven and working fine. At some point I need to wire up a display to it so I can see the lambda reading :)
subver
Post by subver »
Hi All,
I'm developming my own bosch lsu controller and i have some "problems" :)
My circuit is similar to that posted on first page, i have an "virtual ground" point at 2.5V and an amplifier of pump cell current sensing resistor (62 Ohms).
When i run test for first time, i've got strange behavior:
1. I set pump current to "0" (potential on Rcal:1 point is equivalent to "virtual ground")
2. I set heater power to value, when Nernst resistance is near 300 Ohm
3. Then i've injected small portion of butane from cigarette lighter to measurement chamber of sensor (bosch lsu 4.9).
4. Voltage on Nernst cell have raised to value a little over 1V, but the same time current signal from pump cell is showing current.
Is the pump cell of sensor produce voltage signal, when reach mixture is inside measurement chamber?
I have checked points of "virtual ground" and potential on other end of pump cell and this voltages holds on their levels all time.
P.S. sorry for my english :(
toalan
Wideband Wizard
Post by toalan »
Whenever there is a O2 concentration difference between the sample chamber and the pump/nernst cell there will be a voltage generated. That is probably not the best wording, there are proper electro chemistry terms that eludes me.
The oxygen sensor is more or less a symmetrical device. Look at the 3rd diagram from the bottom of this page http://www.wbo2.com/lsu/lsuworks.htm. Referencing that picture, above the sample chamber and below the sample chamber, is made of the same materials. If you were to pump exhaust gas into the bottom (replacing the free air) and pump free air to the top (replacing the exhaust gas), you can swap the terminals and the sensor will still work.
Since the nerst voltage changes WRT O2 concentration between the sample chamber and the free air reference chamber this also means the pump cell voltage will change WRT the O2 concentration between the sample chamber and the exhaust gas.
The above is for the LSU 4.2, but it is the same idea with the LSU 4.9.
subver
Post by subver »
Ok, thank you. Now i have some understanding of processes running in wbo ))
However, i've replaced my pump drive VOLTAGE source with CURRENT source and get much,much smooth operation near stoich point of mixture )
FeRan
TO92 - Vaguely active
Post by FeRan »
Hello everyone. I'm still quite new to electronics. and do not understand many things. Please explain to me how your scheme broadband oxygen sensor works , I'm interested in what you were guided in its design ? Hell Fire could you put on github your final scheme design and possibly drawing PCB , and a list of used electronic components to be mounted on board , as I do not know how to pick them up myself. Thank U.
subver
Post by subver »
Hi All, I have reassemble my LSU 4.9 controller and have tested it on car. And i have strange results.
I put sensor deep inside exhaust tailpipe of my 06MY Subaru forester, warmed up engine and see measurements while engine idling.
On OBDII Scanner mixture shows lambda 1.0 (AFR is 14.7), but my controller shows AFR 17.2-17.3. And same value i've got while testing on other vehicle.
Is any assuptions of this results? Maybe target resistance of nernst cell is wrong? nernst voltage is about 0.5V
Could you tell me wich values of voltage and current of heater in steady state of your sensor?
subver
Post by subver »
Okay, i have found a bug in my mcu firmware, now my controller shows right values for AFR. How it works:
1. Standart heater control with MOSFET and PID regulator. Resistance of nernst cell is measured by pulsing AC coupled signal to cell, than amplifier and peak detector used to measure level of pulse.
2. Nernst control done by relay-control of current:
MCU sends current to pump cell in both direction with current source realized with OpAmp, Nernst voltage feed to MCU's analog comparator, comparator level is set for 0.5V for "positive" current flow, and 0.4V for "negative" current flow. So, mean voltage of nernst cell is kept on level of 0.45V
Then time of "negative" and "positive" current pulses measured with timer and "duty" cycle calculated. This duty cycle shows mean current, flowing in pump cell. Than table search-up made for lambda calculation.
3. Board has an USB interface for PC communication.
Controller board
Controller board
Engine idling
Engine idling
Sensor warm up
Sensor warm up
joey120373
Post by joey120373 »
Wish i had found this post back in '13.....
Hell-fire, I am going to port your shem over to KiCad as it is what i use mostly these days.
I have a couple of ideas, possibly a UNO shield using mostly through hole stuff to test with and a smaller SMD board using a pro mini for real world use.
A few questions....
1, are you still using this?
2, have you tested it to see how accurate it is?
3, I am a huge teensy 3.1 fan, however it is a 3.3v device, how hard would it be to make this hardware/software work on a 3.3v chip?
The Teensy 3.1 has an on board DAC that might be useful, and it is quite a bit faster than standard arduino 8 bit boards.
joey120373
First proto boards are done for use with a pro-mini, ittle be a couple weeks at least before I can get the boards assembled, then assuming I didn't make any huge errors on the schem and board layout I can start testing.....
