EMStudio Screenshots: Post Your Cool Screenies Here!
Mike's cross-platform FreeEMS tuning application, written in C++ using QT. With Mike's natural coding talent and Fred's intimate requirement knowledge it went from concept to full tuning capability in just 8 weeks!
One image per post to keep the per-page weight down! Multiple sequential posts are OK, but limit it to 5, preferably 3 or less.
This is not mine, but it is BMWPower's and it's running on Windows 8:
m2cupcar
Re: EMStudio Screenshots: Post Your Cool Screenies Here!
Post by m2cupcar »
2014 bump!
Quick, shut off your engine, it's going to melt! :-D Also, put on some clothes, at -67C you're going to freeze!
Fancy timing table! You realise you can use a lot coarser axes and go fine step once you have it rough tuned? Or is that Ben's default table we're looking at?
Please export your real timing table as a .json and send it to me so I can sort you out some custom ready to run firmware sometime soon :-)
m2cupcar
Post by m2cupcar »
Fred wrote:..You realise you can use a lot coarser axes and go fine step once you have it rough tuned?
That's mine- no I didn't realiZe that. Just used the table that came up and adjusted values to match timing from the prior ecu.
