This is not mine, but it is BMWPower's and it's running on Windows 8:
That's mine- no I didn't realiZe that. Just used the table that came up and adjusted values to match timing from the prior ecu.Fred wrote:..You realise you can use a lot coarser axes and go fine step once you have it rough tuned?
