Eye-candy first!
It already has some good bolt-ons (the ones I can remember are):
- NPC heavy duty button clutch (the missus' ass lifts off the seat when she tries to depress the clutch pedal, epicly funny to watch)
- SARD fuel pressure regulator
- Front mount intercooler (a little dinged up, so I will replace that one day)
- Boost controller (gay manual tap/bleed type) <-- this will be replaced with an eboost or similar
- Battery relocated to the boot
Current plan's are (in chronological order):
- Register it! (also go and get a potential "before" dyno power run)
- Upgrade stock turbocharger to Precision Ball-Bearing 5557SP unit and run with a TIAL 38mm MVS external wastegate (vented to atmosphere of course)
- Swap out OEM ECU internals for a new PCB running FreeEMS! see this thread for updates -->viewtopic.php?f=62&t=2257
- Plaster part of the exterior of the vehicle with FreeEMS propaganda!
- Upgrade intake manifold to front-facing plenum
- Install blow-off valve (also vented to atmosphere)
- Rebuild with good shit (forged pistons, blah, blah)
- Crank up boost to something respectable (20 - 30psi) with the use of an eboost or similar
- Get a potential "after" dyno power run
- Pull a PHAT skid! (will provide video link)
Good times ahead!
