View unanswered posts | View active topics It is currently Mon Sep 23, 2019 2:10 am
Reply to topic  [ 10 posts ]
Standalone Idle Valves
I'm hoping a few people can come up with different models/makes/OEMs of idle valve (PWM 2/3 wire, or stepper (4 wire)). Please post picture(s), source vehicle(s), model/make of valve, comments/anything else you want to say. One valve per post.
I know there are various Bosch valves. I know some of those flow HUGE amounts of air, some flow sensibly. I'd like to see those. But are there any Jap ones that aren't integrated into the manifold? I'd like to see those too.
Go! :-)
Sun Sep 15, 2013 7:06 pm
My ford sierra has a Bosch 2 wire PWM idle valve.
(pic is not mine)
Sierra XR4i 2.0T
Sun Sep 15, 2013 10:37 pm
This the valve i'm using in my Golf at the moment. It's a 3-wire Bosch valve.
TODO: measure the inlet and outlet diameters
Bosch partnumber: 0 280 140 505
Heres a list of oem numbers:
VOLKSWAGEN 034133455
VAG 034133455
KIA 0K01120660
FERRARI 142432
HYUNDAI 3515022000
FIAT 60562537
FIAT 60813324
FIAT 7637024
IVECO 7637024
SAAB 8857179
Sun Sep 15, 2013 10:40 pm
I also have few of these 2-wire Bosch valves available. From an early VW VR6 engine and from several Opel engines we have at the workshop.
It'a bit larger than the 3-wire valve I posted above. It also has a calibration screw but it's heavily glued and hard to adjust without braking it.
Bosch partnumber: 0 280 140 516
VOLKSWAGEN 0269060496
VAG 0269060496
CITROEN 034542
PEUGEOT 034542
VOLVO 1389618
VOLVO 1398618
ALFA ROMEO 195321101701
VOLVO 3450181
FIAT 60513207
FIAT 60813370
SAAB 758601
SAAB 7586019
RENAULT 7700271089
FIAT 7766481
IVECO 7766481
IVECO 8011038
OPEL 837101
OPEL 90271799
CITROEN 91540797
PEUGEOT 91540797
Sun Sep 15, 2013 10:45 pm
I'm assuming the two wire valves are just a pwm input.
One side +12V, the other pwm output by a suitable fet to GND.
Is this correct?
Lenny
Mon Sep 16, 2013 2:14 am
Is this correct?
Yes.
Mon Sep 16, 2013 4:26 am
Using this (3-wire) one on my e30:
Bosch part# 0280140509
Used on many BMWs and Porsches
Fri Oct 18, 2013 9:45 pm
By standalone, I guess you mean hose fittings for both in and out? If so, then this isn't so relevant :roll: , but I'll add it in anyway as it's a useful valve.
This 6-wire (or commonly called 5-wire) stepper idle valve (ISCV/IACV) is used on many 80/90s toyotas (eg: 1UZ-FE, 1G-GTE, 1J, 2J, etc).
Here it is pulled apart for curiosity:
It fits an easily machined flange if you want to incorporate it onto a manifold:
The step in the flange makes it a bit trickier to make, and is for an easily removed one-way valve to prevent boost from escaping off-idle with the valve cracked open:
It's pretty easy to control, as it has two center-tapped 12V windings, each one is measured at ~20ohm.
The connector is from the Sumitomo MT 090 family. Cconnector P/N is 6189-0029, terminal P/N is 1500-0110 (Small bucket), 8240-4828 (Large bucket).
It can easily be found at the wreckers, or if you want it new (for a very wide range of prices) start with places like:
https://www.chasebays.com/brands/chase- ... -connector
http://store.wiringspecialties.com/toidaircoco.html
http://kyae.en.alibaba.com/productlist.html (if you're willing to order 500, and confirm quality first!)
http://store.driftmotion.com/static/i-i ... nector.php
http://www.tweakdperformance.com/online ... ucts_id=40
I've found it to be quite a robust and easy to control valve (even with MS).
Cheers,
Timbo
FreeEMS projects
- None (yet)
Others
- Toyota 1UZ-FE MS2 (twin VR, stepper idle); 1G-GTE MS2 (24/2 VR, stepper idle, boost control), 1G-GTE MS2 (24-1 missing tooth VR, stepper idle, low-Z); 18R-G MS2 (Points triggered); 4AGE 20V MS2 (factory wiring and sensors, 24/2 VR, 3 wire idle); and others...
Sun Nov 17, 2013 9:07 am
MrOnion wrote:
I also have few of these 2-wire Bosch valves available. From an early VW VR6 engine and from several Opel engines we have at the workshop [...] Bosch part number: 0 280 140 516 [...] VOLVO 1389618; VOLVO 1398618 [...]
Yeah these seem pretty prevalent on '90s Volvos, there's one on my '97 940, I just checked a '94 engine that was either from a 700/900 series and it has one, and there's one on my dad's '93 240.
Wed Apr 09, 2014 7:46 pm
So many dead images, so sad.
Here's one that Tek brought to our collective attention yesterday in IRC:
(00:09:02) TekniQue: I found a low profile pwm idle valve with hose fittings
(00:09:27) TekniQue: Yamaha FJR1300 motorcycle
(00:12:14) TekniQue: http://imgur.com/c2YgS32
(00:12:46) TekniQue: since you were looking for one yesterday
(00:13:49) TekniQue: it has one inlet and two outlets to feed each half of the itbs
Wed Jul 27, 2016 9:46 pm
