Another Bad Wideband You Shouldn't Buy :-/
molak
Re: Another Bad Wideband You Shouldn't Buy :-/
Post by molak »
pishta wrote:Alan, what is the story on the new one? And what wideband do you all suggest? Stock VW Golf? Ill be buying one shortly. Thanks .
If you buy the sensor from a GOLF GTI you still need a wideband controller....
Check alan's web http://14point7.com/
You can get a spartan for $105, ready to interface with your aftermarket ECU..
pishta
Post by pishta »
Do i need a controller for jaguar or MS? Or do those just work with widebands if you tell them too? Not wanting a stand alone. Thanks.
Spartan is a good choice for standalone use, it is both the controller and the sensor in a single unit.
What do you mean "Not wanting a stand alone."?
toalan
Wideband Wizard
Post by toalan »
To BPSX's credit, he sent me free of charge a complete unit, pre connected, pre calibrated, pre wired, All I had to do was hook up power and ground.
The result of this, the 3rd unit, is the same as the 2 previous units; with 11.78 AFR gas, the unit reads max rich 7.xx . I scope the signals and the unit electrically behaves all over the place like the other 2 units.
I did not want to beat a dead horse, so I did not post my result until someone (you) asked for it.
Joseph Davis
Post by Joseph Davis »
Color me unsurprised.
Evolution-VII
Post by Evolution-VII »
What a messy welding job, damn!
Someone downloaded the video? It is unavailable, I could use it to have some fun :mrgreen:
