View unanswered posts | View active topics It is currently Sun Jan 20, 2019 7:09 pm
Reply to topic  [ 26 posts ]  Go to page Previous  1, 2, 3
Simple Transient Enrichment Brainstorming
1) Yep, already fully implemented, just not shared, for various reasons. The only reason for non-TPS algos is a lack of TPS. Future refinements to current impl likely in terms of units and so forth.
2) RPM has another effect, more injections to stabilise into equilibrium for a given time frame.
3) Yep, all the tables are X vs RPM. Full pulse shape control over the entire RPM band.
4) Carb pump works on volume, same volume is induced much faster at higher RPM. If you have a 200ms enrichment then that's tiny at low RPM and HUGE at high RPM. By volume automatically compensates.
Thu Aug 22, 2013 2:36 pm
The problem with just using a pure delta is that at low RPM only the fist X% of throttle movement will have an effect on airflow. IE if you are at idle and you wap the throttle to 50% there will be a huge increase in flow vs If you are lugging your engine on the highway and wap the throttle you may actually flood it out a bit. That was my reason for at least wanting to see how effective using the "fueling/PW delta" is.
Quote:
A carb pump doesn't know anything about RPM,
It's sort of self-correcting. The accelerator pump dumps a flat amount of fuel based on throttle movement. The same movement at a higher RPM will automatically spread that shot out over more cylinder events.
You snooze, you lose!
Thu Aug 22, 2013 5:10 pm
Profile YIM
Although this is true, the amount you need for initial opening is a small proportion of what you've already got at a wider opening.
I swear there's a fucking echo in here! If no LT1 log + vid + rip that all match in the next 7 days, I'm turning off your postability so you can focus better :-p
Thu Aug 22, 2013 7:05 pm
Sean, if you can get a log together, do you mind posting it? This is one I'd love to play back in realtime.
-Jeff
Fri Aug 23, 2013 3:16 am
Hi Jeff,
Sure, but which engine ? R1 is available now, LT1 soonish.
-Sean
Fri Aug 23, 2013 4:07 am
Profile YIM
/me is a closet LT1 fan. This will be like watching an EKG strapped to a celebrity pr0n star.
-Jeff
Fri Aug 23, 2013 4:37 am
