Andg support role
For people running FreeEMS to discuss it and ask any questions about using and adjusting it.
andg
SOT-223 - Salvaje
Andg support role
Post by andg »
If you need firmware or system software Doc or write up on or my primitive QC checks against any firmware tool loader, bench tester, or dash ideas you may ponder feel free to bounce them at me if you want a second or fifteenth look at something.
Re: Andg support role
viewtopic.php?f=41&t=1608 Sign up here! :-) And/or keep an eye on it for requests.
Also, just thrash the tools and find faults. Sim found this last night, the hard way: http://issues.freeems.org/view.php?id=838
andg
SOT-223 - Salvaje
Post by andg »
https://github.com/AndrewGauger/freeems-vanilla/pull/1
I commented on the pull request.
     `'q'`     \       /
        ) .-'"'-.`'q'`
           `'q'`   ( \       /
              )        `'p'`
was the messed up comment here, github stole my whitespace. It was referring to the comment
fred wrote:// Else do nothing, we're running!
How very useful of you! :-) https://en.wikipedia.org/wiki/Ritalin
andg
SOT-223 - Salvaje
Post by andg »
I think of it more as compulsive than attention deficit. You took my balloons. I guess I didn't post the balloons then. Nevermind. I had some ascii art balloons that github messed up so I posed in a code block, or so I though. Later found my balloons in preview on another tab on another computer.
What balloons?
andg
SOT-223 - Salvaje
Post by andg »
I'm trying out
sudo apt-get install qt-sdk
to see if it alleviates some dependency isses.
Fresh 12.04 desktop ubuntu
eMStudio
Fred want's camel
sudo apt-get install build-essential libqt4-dev libqt4-opengl-dev libqt4-opengl-dev qt4-qmake libqwt-dev libqt4-declarative libqjson-dev
successful make. I didn't know the right dependecies so I ran:
apt-cache search glut
sudo apt-get install libglui-dev libmgl-glut5 libmgl-dev
Later ran with a fresh vm with this:
user complaint I don't have a search for com port. I have many com ports on this computer and it detected the wrong one. Baud rate should be drop down. camel case is no place on labels, this is user interface. BE SPEIFIC. send delay(ms) is fine. Don't bother with help if you only have an about.
Seemed to have a bug where having a file open and then trying to open it again returned an error that could be handled with just returning.
I finished setting up the mac with this:
  • * oracle VirtualBox107 MB
    * VM from SourceForge 603MB
    * extract the package
    brew install p7zip
    7za x ubuntu-12.10-desktop-i386.7z
    mv ubuntu-12.10-desktop-i386 ~/ubuntu
    cd ~/ubuntu
    * set up these programs, add machine and start. Login as ubuntu/reverse. Configure Keyboard layout
    * instructions on github
    * Appended to the notes:
    sudo apt-get install libglui-dev git
    make install
me pretending to post on facebook
Thanks for testing :-)
andg wrote:user complaint I don't have a search for com port. I have many com ports on this computer and it detected the wrong one.
I think it's in the tracker? It's on the TODO though. A bit too much work for the gain right now.
Editable drop down, OK. But on non-linux platforms, it's more flexible than fixed numbers.
Good spotting, but "Inter-byte delay (ms)" is what it should say, "send delay" means very little to me.
Menu is obviously a place holder for more. He could/should bang a URL opener in there for his forum section, though :-)
GOOD FIND! More detail, please! BE SPECIFIC. :-)
andg
SOT-223 - Salvaje
Post by andg »
rebooted.
opened terminal
`emstudio`
load offline data
`forbenofflinedata.json`
open
File
Load offline data
Result:
Error loading JSON. Location ID 0x8000 ram mismatch. Tuner isRam value is fale but json has isRam value of false. Unable to finish loading JSON file. Please check your JSON file to ensure it is not corrupt.
Logged, advised this should have been logged as any/any/any platform
