View unanswered posts | View active topics It is currently Wed Sep 30, 2020 11:51 pm
Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
Andg support role
SOT-223 - Salvaje
If you need firmware or system software Doc or write up on or my primitive QC checks against any firmware tool loader, bench tester, or dash ideas you may ponder feel free to bounce them at me if you want a second or fifteenth look at something.
Code:
Sun May 05, 2013 3:55 am
viewtopic.php?f=41&t=1608 Sign up here! :-) And/or keep an eye on it for requests.
Sun May 05, 2013 10:54 am
Also, just thrash the tools and find faults. Sim found this last night, the hard way: http://issues.freeems.org/view.php?id=838
Sun May 05, 2013 10:55 am
SOT-223 - Salvaje
https://github.com/AndrewGauger/freeems-vanilla/pull/1
I commented on the pull request.
Code:
     `'q'`     \       /
        ) .-'"'-.`'q'`
           `'q'`   ( \       /
              )        `'p'`
was the messed up comment here, github stole my whitespace. It was referring to the comment
fred wrote:
// Else do nothing, we're running!
Code:
Tue May 07, 2013 1:05 am
How very useful of you! :-) https://en.wikipedia.org/wiki/Ritalin
Tue May 07, 2013 9:45 am
SOT-223 - Salvaje
I think of it more as compulsive than attention deficit. You took my balloons. I guess I didn't post the balloons then. Nevermind. I had some ascii art balloons that github messed up so I posed in a code block, or so I though. Later found my balloons in preview on another tab on another computer.
Code:
Tue May 07, 2013 2:10 pm
What balloons?
Tue May 07, 2013 2:16 pm
SOT-223 - Salvaje
I'm trying out
Code:
sudo apt-get install qt-sdk
to see if it alleviates some dependency isses.
Fresh 12.04 desktop ubuntu
eMStudio
Fred want's camel
sudo apt-get install build-essential libqt4-dev libqt4-opengl-dev libqt4-opengl-dev qt4-qmake libqwt-dev libqt4-declarative libqjson-dev
successful make. I didn't know the right dependecies so I ran:
Code:
apt-cache search glut
sudo apt-get install libglui-dev libmgl-glut5 libmgl-dev
Later ran with a fresh vm with this:
Code:
user complaint I don't have a search for com port. I have many com ports on this computer and it detected the wrong one. Baud rate should be drop down. camel case is no place on labels, this is user interface. BE SPEIFIC. send delay(ms) is fine. Don't bother with help if you only have an about.
Seemed to have a bug where having a file open and then trying to open it again returned an error that could be handled with just returning.
I finished setting up the mac with this:
    * oracle VirtualBox107 MB
    * VM from SourceForge 603MB
    * extract the package
    Code:
    brew install p7zip
    7za x ubuntu-12.10-desktop-i386.7z
    mv ubuntu-12.10-desktop-i386 ~/ubuntu
    cd ~/ubuntu
    * set up these programs, add machine and start. Login as ubuntu/reverse. Configure Keyboard layout
    * instructions on github
    * Appended to the notes:
    Code:
    sudo apt-get install libglui-dev git
    make install
File comment: me pretending to post on facebook
Code:
Wed May 08, 2013 4:25 am
Thanks for testing :-)
I think it's in the tracker? It's on the TODO though. A bit too much work for the gain right now.
Editable drop down, OK. But on non-linux platforms, it's more flexible than fixed numbers.
Good spotting, but "Inter-byte delay (ms)" is what it should say, "send delay" means very little to me.
Menu is obviously a place holder for more. He could/should bang a URL opener in there for his forum section, though :-)
GOOD FIND! More detail, please! BE SPECIFIC. :-)
Wed May 08, 2013 9:24 am
SOT-223 - Salvaje
rebooted.
opened terminal
`emstudio`
load offline data
`forbenofflinedata.json`
open
File
Load offline data
Result:
Error loading JSON. Location ID 0x8000 ram mismatch. Tuner isRam value is fale but json has isRam value of false. Unable to finish loading JSON file. Please check your JSON file to ensure it is not corrupt.
Logged, advised this should have been logged as any/any/any platform
Code:
Thu May 09, 2013 1:03 am
