View unanswered posts | View active topics It is currently Sat Jun 06, 2020 3:03 am
Reply to topic  [ 22 posts ]  Go to page 1, 2, 3  Next
OLV Release Delays
I've been meaning to get OLV 0.0.3 out the door for a while now, however, it's not happened yet. There are a number of reasons why not, so I thought I'd share them here.
  • New changes use new plugins, all of which are almost perfect, none of which are good enough. I can fix each of them myself, and release, however doing that work, which IS wasted, is not a priority.
  • In sussing out those plugin issues, I burned quite a bit of time on them.
  • I moved a few more issues into the release and performed the bulk of that work, which took a while.
  • The two new libs that the new code uses aren't 100% and aren't released yet, either.
  • I need to do some further design work on the final aspect of the changes, which is core to the release.
  • I spent the last 5 days making myself independent of currently available loading solutions, none of which were up to my (admittedly very high) standards.
  • Although I did most of the translation base stuff, I didn't complete it due to "future" changes in various parts. I still need to do that work.
  • I currently have 4 branches based off of the end of my private changes, most of which are data tweaks for custom logging. I want to break free of that shackle and get down to just one as rebasing four mixed branches when something on the public base changes is a slight pain.
Summary, I'm working on other related things at full steam in the mean time, and if/when I am done with those things, I'll do the required hacks on the plugins, and push those changes.
If any of the plugins get released/fixed in the mean time, I'll push the associated changes ASAP and retain the remaining stuff locally.
IE, I'm releasing what I can cleanly release. To push changes prematurely would mean pointless repository churn tweaking things that I already knew were wrong...
Thu Oct 11, 2012 5:07 pm
I just got some updates on one of the plugins, hopefully more soon. 1/2 of the issues needing resolution are closed now. Just one to go, then I can push more updates.
Tue Oct 16, 2012 11:42 pm
Just released and signed and uploaded a new version of another one required for the release. Hopefully that gets synced to central soon :-)
Thu Oct 18, 2012 11:08 pm
The one that I already released, I just released again, but to central, and myself. I'm now an official user on the sonatype oss nexus instance with ability to deploy! Cool :-)
Should be available tomorrow morning, with luck.
Sat Oct 20, 2012 1:50 am
It became available overnight! This is good news :-)
Tue Oct 23, 2012 2:31 pm
The forum doesn't notify me of any new posts in the OLV section like it does for all the rest (clicking "view active topics"), so I haven't been following along. It is good to see the updates!
BenFenner's 1994 Black SE-R
Wed Nov 14, 2012 2:44 pm
Latest update from one of the hold ups: "Hey - unable to get any free time again... Unbelievably busy days :/"
Latest from me: viewtopic.php?f=8&t=57&p=30561#p30561
Wed Nov 14, 2012 3:03 pm
Thank you for notifying me. Fixed for a number of forums...
Wed Nov 14, 2012 3:06 pm
Looks like I'll soon have access to officially fix one of the plugins that needs work.
Thu Nov 29, 2012 10:25 pm
As soon as I accept the position, this is true. I'm hoping Jeff will give me a hand with that :-)
Tue Dec 04, 2012 11:50 pm
