Mitsi 4g63 DSM/Evo and NA Miata 4and2 CAS Decoder
For discussing and developing different RPM/Position decoders using our superior modular architecture! One thread per pattern, please.
Re: Mitsi 4g63 DSM/Evo and NA Miata 4and2 CAS Decoder
http://issues.freeems.org/view.php?id=110
Done tonight, with a slight hack that I'll clean up when I get a chance. On a temp branch until then. Needs an angle tweak too, and more of the sync points implemented, but this is good enough for the time being. Sync inside 360 degrees max as is, syncing only on inner track.
Upgraded to 4 sync points from 2. Enjoy! :-)
This is the annotated version of the diagram with event numbers as per the code.
This decoder is now pushed and available in the dev branch, FYI.
First one shows that you might wait up to 4 edges before you get sync, depending on engine position when you hit the key:
Second one shows the states and actions and so forth, excuse the crappy colours:
