View unanswered posts | View active topics It is currently Sun Mar 24, 2019 3:56 am
Reply to topic  [ 4 posts ]
Other micro-controller projects
:?: I was just wondering if anyone had other small micro-controller projects they were working on?
I am just starting out with micro-controllers but already have a few projects I am thinking of using them for. Eg:
* A Lithium batt. controller for charging, balancing,indicating & safety cut-off on portable cameras at work.
* Smart controller for solar-water heating/room temp. control.
* RC batt. discharger & voltage/current display.
:?: And does anyone have good links for tutorials or lessons?
Wed Aug 06, 2008 5:07 am
Here is a good "intro into various types of micro's" article i came across
http://www.ferret.com.au/c/Microchip-Te ... rs-n692721
I am also discovering this wonderful world.
currently looking at ARM7, Parallax propeller. Cortex-m3 and PSoC are on my todo list.
currently dicking around with CAN bus
tutorials and lessons? google is your good friend, just need to put a bit of effort to search around - it's all there.
Alex
Fri Aug 08, 2008 4:05 pm
TO92 - Vaguely active
Alex
I know this is old but saw your mention the parallax propeller. I started using it. Have switched to programing in prop basic.
Wed Jun 06, 2012 5:19 pm
Some of the projects I have in the pipe line are based around CAN bus enabled sensors and displays. Such as fuel sender, G-sensor, wheel speed and LCD Dash display.
I had not used the Microchip PIC controllers until about 2 years ago when I changed jobs. I have to say that I am very impressed with them.
They do have some configuration bits that can catch you out but come with a good C compiler and debugger. You would need to get yourself a PICkit 3 programmer / debugger, but it will program most of the Microchip family.
I am going to be using the PIC 18F25K80 for my CAN projects. They are a small cheap micros with CAN bus built in.
Fri Jun 08, 2012 8:27 pm
