Summary
The FreeEMS IRC experience is split over three special-purpose channels:
- #freeems-dev - Development discussion
- #freeems - User support discussion
- #freeems-ot - Off-topic discussion
/join #freeems-devhttp://webchat.freenode.net/?channels=% ... angeUrNick
We use the irc.freenode.org service for these channels if you're connecting with a client and need to know.
Note, you should copy this URL and change the nickname to something appropriate to you. Also note that it tends to be somewhat fragile in terms of the connection and doesn't allow reconnection AFAIK. Correct me if I'm wrong on that last point.
Below I'll add a post per channel with the guidelines inside. I'll also post on general etiquette, however the majority of you don't need to read that. I'm sorry for including it, but some do need to read it. Sadly those that do likely won't absorb what they should from this guide anyway, but one can only try. Finally I'll post some commands that I use (for my reference) and the reasons that I use them (for yours).
