http://anonym.to/?http://www.msefi.com
So now you don't know why your post are deleted.
It's sad that the official megasquirt forum doesn't want to help the majority of megasquirt users.
Con
Wow, two settings to do the SAME thing!!! WTF? :-/James Murray wrote:Trigger angle/offset should be set to zero when using "Trigger wheel", use the tooth#1 setting instead. This is stated in the MSEXTRA manual.
http://anonym.to/?http://www.msefi.com/ ... .php?f=102ca7 wrote:The "temporary forum for msextra topics" has been removed from msefi.com![]()
No, but it is vaguely similar.Fred wrote:Do you use the same username over there?
