Dan's 4AGTE 20V 1967 Toyota Corona
Dan
Re: Dan's 4AGTE 20V 1967 Toyota Corona
Post by Dan »
EDIT: removed irrelevant information. . .
Are you running a dual pump setup with a surge tank? Or planning to foam fill? or going to use a sump under it or something? Or just keep it full all the time? Curious on your plans :-)
Dan
Post by Dan »
will be putting some more baffling in it around the pickup, the tank slopes downwards at the rear, and when I launch hard it should push fuel towards the pickup and prevent surging. should be no need for a surge tank, but may fit one if i find it is still surging. I doubt it will though.
be careful with baffling as they can keep fuel away from the pickup as well as near it. All they really do is reduce slosh.
Slosh is the enemy, though, and when you launch it will all go back, and then up the back wall, and down again, and so on.
Give me a skype tomorrow morning and I'll chat with you about fuel and oil systems :-) If you want. No pressure.
Dan
Post by Dan »
all good mate, as I said, if it isnt that good at reducing 'slosh' I will go the surge tank route anywho.
Just finished welding it up too, should be cool to start fitting it and my $600 worth of hose and fittings tomorrow! :-)
Dan
Post by Dan »
well i just collected my proflow order.
They sent me everything I ordered EXCEPT for the god damn 1/2" aluminium hard line! Cant do sweet F-all without that.
I contacted VPW to inform them that they are retards, hopefully they wont be dicks about it and will sort it out. I have told the guy I dont have the hardline and he asked me to go through the whole order and mark off what I am missing. I did that, am only missing the hard line, tried calling him back twice, left two messages with his work mates to call me back.
They better not be shafting me on this...... Grrrrrr!
Dan
Post by Dan »
Photo # 1 - The mass of fittings and teflow hose (not including the 25ft roll of 1/2" hardline that they didnt send me, it is on its way to me now though)
Photo #2 - Spent a few minutes fiddling with some of the -08AN fittings and teflon hose.
Dan
Post by Dan »
ACCEL DFI -08AN fuel pressure regulator and my new injectors arrived yesterday afternoon! Just waiting on the aluminium hardline now!
Dan
Post by Dan »
New injectors are here!
Also picked up my aluminium hard line finally too! Fuel system install pics coming soon!
Dan
Post by Dan »
New injectors and regulator fitted!
