Supported Ignition Systems
DeuceEFI
Post by DeuceEFI »
This is the place to discuss the supported ignition systems for Jaguar.
Edit: 01-24-21012
Current supported ignition systems are GM DIS Wasted Spark, GM Electronic Advance High Energy Ignition (HEI).
It has been suggested to find out what it would take to run Ford EDIS as well and I am currently researching that information.
Re: Supported Ignition Systems
What's supported? :-p
DeuceEFI
Post by DeuceEFI »
Wow, you're fast! I just wanted to test to see that I could create a topic and you found it before I could edit it :-)
DeuceEFI
Post by DeuceEFI »
From my research it appears that the Ford EDIS is very similar to the setup for the GM DIS system...
EDIS doesn't need the 5vdc DIS-Bypass output from the XOR chip to tell the module the engine is running.
EDIS only needs one input, use the CRANK+ input and don't connect the CRANK-, CAM+ or CAM- inputs.
Yep, that's what I thought, too easy :-)
BTW, you should add that it's suitable for direct drive wasted spark on a 4 cylinder with sequential fueling if using a dumb external ignitor and a suitable set of inputs.
DeuceEFI
Post by DeuceEFI »
Fred wrote:Yep, that's what I thought, too easy :-)
Duly noted, I will add it to the documentation :-)
