Author |
Message |
HotCat
Emacs is my favorite editor, I started to use it since 2003 after graduating from high school, I can't image working on Unix-like environment without it, just like driving a car without steering wheel. Emacs is so Powerful, so flexible and so complex, I can't thoroughly explain how to use it. Instead I only focus on how to navigate through FreeEMS source code 1.First download GNU gtags package Attachment:
2.Use Emacs compile mode to configure, compile and install package Attachment:
3.Locate gtags elisp extension file and open it Attachment:
Wed Jan 18, 2012 5:16 am |
HotCat
4.Follow the comments to configure your emacs Attachment:
5.Navigate to FreeEMS source directory and run shell command 'gtags' from Emacs Attachment:
6.Three file should be generated Attachment:
Wed Jan 18, 2012 5:18 am |
HotCat
7.Explore what gtags can do with our source code, use 'gtags-parse-file' command to list C functions in a C source file and locate the function body Attachment:
Press 'enter' key to locate the function body Attachment:
here it is Attachment:
Wed Jan 18, 2012 5:24 am |
HotCat
8.Find the macro definition of 'cliConfiguredOffset' using 'gtags-find-tag' command Place cursor around the 'cliConfiguredOffset' variable and issue 'gtags-find-tag' command Attachment:
Press 'enter' key to locate whatever definition you prefer to see Attachment:
See how it was defined for Hyundai Attachment:
Wed Jan 18, 2012 5:30 am |
HotCat
9.Find the definition of 'calculateFuelAndIgnition' using 'gtags-find-tag' command Place cursor around the 'calculateFuelAndIgnition' function and issue 'gtags-find-tag' command Attachment:
Wed Jan 18, 2012 5:35 am |
HotCat
10.Find how the function was referenced using 'gtags-find-rtag' command Place cursor around the 'generateDerivedVars' function and issue 'gtags-find-rtag' command Attachment:
There maybe a few candidates, press 'enter' key to choose which one you love it Attachment:
Here it is Attachment:
Wed Jan 18, 2012 5:39 am |
HotCat
11.Sometimes you have to use 'gtags-find-symbol' command to locate some macro definition When 'gtags-find-tag' command does not work, try this one Attachment:
you must choose Attachment:
Wed Jan 18, 2012 5:42 am |
HotCat
End of this topic, thanks for watching
Wed Jan 18, 2012 5:43 am |
johntramp
Joined: Sat Apr 24, 2010 1:42 am Posts: 119 Location: New Zealand
Wed Jan 18, 2012 9:25 am |
Joined: Tue Jan 15, 2008 2:31 pm Posts: 15376 Location: Home sweet home!
HotCat, cool article, this is the most inspired I've EVER been to use emacs! (More than when my best friend tried to convince me) Still not enough to actually do it, though :-)
If you want to edit it freely in future I can leave it here, or I can promote it to article status in the article section. If I do that, though, you have to ask me to get it edited.
LOL @ johntramp :-)
Wed Jan 18, 2012 11:31 am |
