- I need to determine what caused the timing change (historical testing narrowed that down a lot for me)
- I need to fix the code such that starting is not difficult for him
- I need to calibrate his map sensor
- I need to add a temporary hack for his burnt ADC pin problem (Presto, you need to fix the CPU at some point, as when config goes to file based through a tuner or other app, this support WILL be removed)
- I need to fix the timing code or recalibrate his timing (Sean, beware, you run without checking with a timing light. You could be getting screwed here...)
In other news, Preston has been doing a lot of work on the Spin 1 Puma BOM situation and the results of that are here:
viewtopic.php?f=53&t=1294
This is key to getting more testers on board. So far 2/37 printed boards have been used and it's been 9 months since they were printed... This needs to change!
