Knock sensing ideas and circuit designs
Author |
Message |
Ubuntusser
TO92 - Vaguely active
Hi. Maybe it will be useful http://svn2.assembla.com/secu3app/browser/knock.cUnfortunately, comments are non-english
Wed Oct 13, 2010 3:17 pm |
Joined: Tue Jan 15, 2008 2:31 pm Posts: 15216 Location: Home sweet home!
Thanks for the link! :-)
Wed Oct 13, 2010 10:52 pm |
jharvey
1N4001 - Signed up
I just heard this from Intersil, figured I'd post it. Quote: Hi Jared,Unfortunately the people with the expertise on this part have long left the company. I had some experience with this device earlier in my career and the HIP9011 was a spin of the original HIP9010 device. The HIP9010 has additional details about the test mode that should also be applicable to the HIP9011 device. Take a look at page 8 of the following linked document and see if that is helpful to you. http://www.intersil.com/data/fn/fn3601.pdf
Sat Oct 30, 2010 12:27 am |
Wow! That's a sad admission for a company to make! That its IP was lost and not transferred to a new employee or at least documented before they left. Wow!
Sat Oct 30, 2010 6:30 am |
jharvey
1N4001 - Signed up
On a quick look they appear to be an exact match to each other. Same footprint, pin out, and several parts of the general structure appear to be the same. I haven't compared the nitty gritty, but they look to be nearly exactly the same. I might wager a guess that because the TPIC is an exact match to the HIP chip, there's some kind of affiliation between the two. Perhaps one bought the other, or rights to the other, or perhaps they were built in the same china foundry and it wondered, who knows.
The Intersil datasheet is from 2006, while the TI datasheet is from 2004, so I don't know which would be the newer silicone. I see the TI chip explains some of the missing chunks of data. For example, it specifies that the on boot the SPI is in the default config, which is echo. It also lists a table for the diag/test functions when TEST is 0. I would wager a guess that the HIP chip would also work with that diag options of the TPIC chip.
That advanced mode is interesting. In advanced mode, a transmission is 16 bits long. You shift in 8, then it shifts out 8. I think that mode will allow the best verification that the data was actually received.
Sat Oct 30, 2010 10:45 am |
russian
Joined: Fri Feb 01, 2013 4:18 pm Posts: 147 Location: Jersey City, USA
As usual, my question might be a bit offtopic... Does anyone know which cars use either HIP9011 or TPIC8101 in their stock ECU? Since I am visiting junk yards often anyway...
Fri Feb 15, 2013 5:24 pm |
Wow, bump from the very dead! Fair question, though.
Fri Feb 15, 2013 5:52 pm |
russian
As funny as it is, my first googling result for HIP9011 is Russian Vaz around 2004.
Fri Feb 15, 2013 6:20 pm |
russian
Siemens ECU in 2005 kia spectra uses TPIC8101
Sat Sep 14, 2013 9:16 pm |
tooly
Joined: Thu Jun 27, 2013 11:04 am Posts: 15 Location: hamburg
russian wrote: Does anyone know which cars use either HIP9011 or TPIC8101 in their stock ECU? HIP9010AB are inside in a Siemens 5WP485904 (audi a3 8L) there is also an LM1815M inside see picture below
_________________oelprinz.org
Mon Sep 30, 2013 9:49 pm |
Who is online |
Users browsing this forum: No registered users and 2 guests |
