View unanswered posts | View active topics It is currently Tue Mar 02, 2021 12:19 pm
Reply to topic  [ 29 posts ]  Go to page Previous  1, 2, 3
Getting set up on github
1N4001 - Signed up
So here are some snap shots of TortiseGIT showing how to setup your authentication.
First got to settings.
Then choose remote settings. The default is origin, here's how mine looks. Also it's easy to "add new", but it's a bit harder to remove junk, so getting it right might be handy. Or modifying an existing one instead of created several might also be handy. Basically choose your names how you want them on the first try.
Also go to the config area. Here's how mine looks. This is required to make you have your name when you check it in.
Here's the key generated by putty.
Here's how it looks in github. Note I stripped a bunch of the file out, and I added the ssh-rsa thing with the space at the end of ssh-rsa. It needs to look this way when you open the key.
After that, you should have read / write access to you account. Of course you'll have to change the jharvey stuff with your account, because you you'll only have read access to my account.
Tue May 11, 2010 11:42 am
1N4001 - Signed up
I just added the picture of the config setting in the post above.
Wed May 12, 2010 2:10 am
viewtopic.php?f=41&t=1103
If you're trying to contribute, this is a guide on how to be polite about it!
Thu Jun 16, 2011 4:40 pm
A great little diagram about the way files move between their four possible states in Git:
If this image doesn't display here, PM me and I'll cache it.
Sat Nov 05, 2011 5:19 pm
Doesn't an untracked file get added to the staging area?
Thu Nov 10, 2011 12:00 am
That is one possibility, yes. I think for the sake of clarity of ideas he has opted to display a different process. I like how clear it is. I didn't understand the 4 states for quite a long time, this would have helped.
Thu Nov 10, 2011 1:08 am
A variation on the diagram from the git book, which I don't agree with, and think is misleading and unclear.
Explanation:
  • On the left are files that are not known to git. New files. Files that have not been committed in the past, or have since been removed.
  • Next to that is the normal default state of a committed and tracked git file.
  • To the right of that is the same file, modified, and showing a dirty status.
  • Finally, on the right is a staging area, where you MUST add new files, and where you CAN add existing modified files.
The original file is misleading in that:
  1. It shows adding a new file as making it tracked, when really, it's just staged, and not committed. Sure, git knows about it, but not in a permanent/semi-permanent way.
  2. It doesn't show adding a new file as being staged and ready to commit, implying that it's committed by adding it.
  3. It doesn't show that you can commit from the modified state without staging anything.
Additionally, mine doesn't show that you can remove something from being staged instead of committing it. Insert a big grey line from right to left at the bottom in your mind.
Fri Mar 01, 2013 12:24 pm
Here the commit from modified to unmodified is wrong too...? Sure, a commit -a can do it in one step, but that is still staging the files.
Fri Mar 01, 2013 10:09 pm
No, it's correct.
git commit README.md
Works just fine. But fails if README.md is brand new. Have to add first in this case.
Fri Mar 01, 2013 10:29 pm
Users browsing this forum: Google [Bot] and 0 guests
