V8/10/12 Sequencial Injection
Re: V8/10/12 Sequencial Injection
Hmmm I haven't seen anyone comment about the use of 2 freeEMS's both as 4 cyls to control both banks sequenctialy for 8 or 12 cyls.
I suspect that folks with the 8's that are pushing the limits, will desire to have extra A/D's, GPIO, ect and using two EMS's will offer that. I think the biggest issue will be the tach signal. Perhaps we should leave a header on the RPM circuit so it's ouput can be routed to a remote EMS?
SleepyKeys
Post by SleepyKeys »
jharvey wrote:Hmmm I haven't seen anyone comment about the use of 2 freeEMS's both as 4 cyls to control both banks sequenctialy for 8 or 12 cyls.
An interesting idea, but my vote goes to making the jump to the XEP100 AFTER we get the Mark-I tested and worked out. XEP100 MCUs are cheap $20< + whatever we end up with for a "CPU Card". Two adapt cards would be a bit pricey IMO let alone two whole FreeEMS systems. As a v8 guy I think I'll be happy with the I/O we have now for quite some time. A header on the RPM circuit could prove to be very useful!
-sean
You snooze, you lose!
AbeFM
Post Whore!
Post by AbeFM »
I like the idea as well, but agree that there's little need for a lot more IO. I guess the bare chip is actually a cheap solution to more ADCs, etc, but I don't want to end up in the MS mindset where it's $100 or more to add a couple inputs.
Designing a mark-II board with a second processor would be awesome, but down the road. I actually have some other projects I want to do which might utilize that, so I'd be in favor anyway.
Really wasn't my idea. Someone here mentioned they did it that way with MS boards, one for each side of a V8. Also I don't think the cost would be to much more to do it this way. I guess one PCB is cheaper then two PCB's, but two chips vs one chip, is most of the variation in cost. You should be able to do it with one tach, temp, ect. I don't object to using a better CPU, but I do think it's a good idea to stear clear of the chip MS3 is using. I think "they" would complain.
tuning multiple boxs like that is a pain though...
there would need to be support for dual tuning in the tuning tool. I could think about that I guess, but I don't see much/any demand for it.
XEP post XDP, sure, but only when XDP is properly decent and finished.
comrade904
Post by comrade904 »
I don't think this would be too bad to tune, provided you know enough to tune 1 unit well. Just program one to read the timing signal offset of what the other reads, and split out the sensors so the resistances are the same for each unit. Then each one won't even know the other exists.
This is an idea I've been wanting to try for some time so I could run each cylinder of an I-4 as for 1 cylinder motors, each with knock sensors, ego, map, and timing control on ITBs. Kind of like a homemade JS Safeguard with alot more features.
In theory they would be tuned the same except for trim and timing offset. Should work beautifully.
SleepyKeys
