Injector Timing Alarm???
Posted: Thu Dec 04, 2008 1:46 am
Ok, I was overclocking my new computer last night and torture testing it and later was thinking about a guy I went to school with who turbocharged his civic.
To make a long story short I ended up making some adjustments to his car because the piggyback system he used to tweak his injector timing and fuel pressure was causing injector pintles to float and flooding the hell out of the car.
Anyways I was thinking it would be a nice feature to monitor the flyback voltage from the injector and then use an algorithem to detect when an injector is not operating as it should. If the injector was stuck open for any reason including excessive fuel pressure used for overboosting, of if an injector failed and was not operating the system could see the missing flyback voltage spikes and detect a problem throwing an injector alarm.
It shouldn't be two hard to implement. What do you guys think?
