I did test this with the saleae a few weeks ago (3 or 4) and found it to be the case that if i just hit the pull up control reg earlier in the boot sequence the length of time post reset that the pin stays on was affected, so it's almost certain.
I've also done some work on the actual pin out requirements and that can be found in the following issue on the tracker:
http://issues.freeems.org/view.php?id=190
Pin out research thread - proof that i'm working on it lol
Re: Pin out research thread - proof that i'm working on it l
